Rust
Old Oct 12, 2009 | 09:36 AM
hogwylde's Avatar
Rust
My '91 Toyota 4x4 developed rust over the rear wheel and my wife's earlier model Accord developed rust at the bottom of the doors. Both of which were common issues back then. What about the Fits?
Are there any areas in which we should keep an eye on or have the Fits not been around long enough to develop rust?
Old Oct 12, 2009 | 11:17 AM
Fat Ping Cat's Avatar
subscribed.. i had my car coated when it was new since i live up north here with the road salts late fall, winter, and early spring. i heard that rust shouldn't be much of an issue but i wanted to at least take some precaution
Old Oct 12, 2009 | 04:54 PM
mine for sure will rust at the rear fender cause tires rubbed off paint clean. hahaha.
i dont plan on touching it up, but will sand off the rust next
spring and repaint.
keep driving your car (gets water out of the doors) and wash it often if you drive in salt.
Old Oct 12, 2009 | 06:26 PM
Daemione's Avatar
No rust on my 07 yet, but I'm keeping an eye on the rear wheel wells - specifically in front of the tires, there's that spot where sand/water/grime collects and sits. Gonna try and scrub it out then spray it down with rubberized undercoating before winter.
Old Oct 12, 2009 | 08:04 PM
Uncle Gary's Avatar
I'm not optimistic concerning durability in the rust belt where I live. New York State dumps 500,000 TONS of salt on the roads here every winter ( I heard this on NPR). The thin, poorly protected metal of the Fit doesn't stand a chance, I'm afraid. I worry about the areas the robotic painters missed, where the primer is showing, like the edges and insides of the fenders. I also expect corrosion in the usual areas like the bottoms of the doors and the rear hatch.
I guess time will tell.
Old Oct 12, 2009 | 08:10 PM
Type 100's Avatar
From my experience:
- Check the doorsills and door frames. Mine has a few spots. The top front corner of the front doors is especially susceptible, as well as the adjoining sill area where it sits flush against when the door is closed.
- If your fenders have had deep scratches due to stone chips, rust can form there. Had a nick of rust on my right front fender. Apparently the offending stone had chipped away down to the bare metal!
HTHs
Old Oct 12, 2009 | 09:08 PM
If you got chips make sure you paint it before snow fall. The rust will eat under your paint and start lifting the paint surrounding the chip.
fun times...
Odie
Mar 20, 2019 10:53 AM
MikeVP
Nov 23, 2010 06:34 PM
SportMTNavi
Feb 6, 2009 07:44 PM
jlfama
Nov 20, 2007 04:35 PM
itsme
Oct 5, 2005 08:30 AM
