Wheel fitment advice needed...
Old Oct 15, 2009 | 12:50 AM
k-man's Avatar
... for my winter tire package from tirerack. Do the specs below look fine for my stock 09 Fit Sport?.... my biggest concern is will a 6.5 tire work with a 175/65-15 tire???? I think the rim may be too wide... i assume offset etc is fine since the overall size is similar... any advice will be helpful, there is already a good amount of snow on the ground
thanks
Elbrus I02
15 x 6.5
Offset: +42mm Backspacing: 5.31" Bolt Pattern: 4-100
Rec. Tire Size: 175/65-15
Old Oct 15, 2009 | 02:34 AM
FitDEEZ's Avatar
if its recomended then it should be alright but i think 185s would be better on a 6.5
Old Oct 15, 2009 | 04:23 AM
Type 100's Avatar
175 seems okay as far as fitment goes...it's pushing the limit though.
Isn't a thinner tire better for snow and ice? Maybe that's why they recommend 175s. Could be wrong - correct me if I am
Old Oct 15, 2009 | 09:10 PM
Type 100's Avatar
Originally Posted by guitar_trance
I've always heard it's not necessarily thinner, per se. It's that the tire should have a "crown," so-to-speak. In other words, no rounded or flat [performance radial type] tires. Also, the taller the tire (from edge of rim to tread surface), the better.
This info is from various dealers and mechanics at garages and tire places over the years.
As far as absolute certain? I'm no mechanic... I'm only quoting other people who are, or who "claim" to be!
Thanks!
I was observing WRC rally cars' extreme studded ice-use tires used for Rally Sweden. They resembled bicycle tires more than anything else - that's how narrow they were
Old Oct 15, 2009 | 10:27 PM
Chad T's Avatar
Narrower is better for snow/ice. That fitment should be fine. The tires will be slightly stretched on there so you'll have to be careful of curbs and such.
Here is my base Fit with the stock 175/65/15 tires on 6 inch rims. 6.5 shouldn't be much worse.
What do you plan to do with the TPMS? Just deal with the light in the winter?
Old Oct 15, 2009 | 10:40 PM
k-man's Avatar
No TPMS on Canadian Fits, so I dont have that problem.... so it looks like 175 is a stretch on the 6.5 but it should work........ but makes me wonder if its worth it with all the pot holes etc in the winter, sounds like a risk... hmmm, I would like to stick with the 175 tires for the winter
Old Oct 16, 2009 | 12:36 AM
AndyEich's Avatar
I ordered the 175s on 6.5s from Tirerack since their site said it was ok. I got a call a few hours later from them (the sales guy was a Fit owner) saying that I really shouldn't do that, despite their website recommending it. They had me switch to a 185/60 and said the slight difference (~1%, I think) in diameter was much less of an issue than putting them on rims that were too wide. It saved me money and the advice made sense.
Old Oct 16, 2009 | 07:44 AM
Chad T's Avatar
You guys lucked out there. The TPMS really makes it difficult to easily switch rims and have it work.
It's not ideal that's for sure. When I need new tires I'll switch to 195/60/15s (not snows though). Those wheels I show are only 6 inches wide so 6.5 will be a bit worse. Mine seem to be fine on the 6 inch rims but there is very little protection on the sides.
If you want to have alloys there are lots of 15X6 Honda rims out there that will fit or maybe find some steelies? Some canadian LX Fit (Insight) rims would probably be narrower as well.
Old Oct 16, 2009 | 08:50 AM
Virtual's Avatar
The stock DX steelies are 5.5" wide but there are also aftermarket 6" wide steelies for even less cash.
IMO the 6.5" are too wide for those tires and is just asking for trouble.
Old Oct 16, 2009 | 05:12 PM
mahout's Avatar
thanks
Elbrus I02
15 x 6.5
Anytime the tire section is greater than the rim width fitment is OK though it means higher pressure to 'flatten out' the tread. In your case 175mm is 6.88" which is greater than 6.5. 15x7 of course is better. I'd be more worried about the 42mm offset getting a bit close to the fender lip.
PS with a back space of 5.31" thats an offset of 5.31-3.25 = 2.06", or 52mm. That'\ll work. If they include the 1/2"rim flange flair out that would mean a 1.56" offset, or 40 mm offset.. Thats a problem.
ieandro
Nov 14, 2018 10:17 PM
Splater
Mar 15, 2013 12:51 AM
thewwkayaker
Oct 19, 2012 10:43 PM
d_2
Nov 19, 2011 06:51 PM
geepondy
Jul 19, 2008 03:44 PM
