rear camber
Old Oct 16, 2009 | 03:49 AM
chinkyy's Avatar
rear camber
are any of you guys using any rear camber kits? any tried the rear washer trick?
also what is the natural camber we get from dropping? can anyone confirm that it is negative 1.5 degrees?
Old Oct 16, 2009 | 04:39 AM
HONDAMATIC's Avatar
its almost same as stock because its a beam axle...........
Old Oct 16, 2009 | 05:11 AM
enjoito's Avatar
they sell this shim thing that u can get like -.9 or +.9 camber from stock
Old Oct 16, 2009 | 11:41 AM
08FitSport's Avatar
My alignment sheet says -1.9 is max acceptable tolerance. I've used springs 1 - 1.5 inch drop and I'm right at -1.9.
Old Oct 16, 2009 | 02:25 PM
HONDAMATIC's Avatar
Just put washers behind your rims easy camber haha.. Since you gotta take off your brakes etc to install those shims I'd set
the camber before buying your rims so you can get the best size
Old Oct 17, 2009 | 06:50 AM
chinkyy's Avatar
hein do you know how to do the washer trick?
Old Oct 17, 2009 | 01:44 PM
HONDAMATIC's Avatar
i havent done it before but it looks pretty basic just a pain in the ass to do, and recheck because you gotta put everything back together and look at how much camber you have or you need a camber gauge and take it all apart for everytime you wanna adjust it a lil bit.. and since the spindle base is a machined surface and youre putting metal washers in there and making everything more crooked i dont wanna be responsible if your wheels break off..
whitefitsport
Oct 2, 2018 10:54 PM
Smsgt178
Dec 17, 2015 03:50 PM
Lil Blue
24
Jan 11, 2011 11:17 PM
illest.GD3.JB.squad
Aug 7, 2010 05:04 PM
Previc93
33
Dec 14, 2008 07:41 PM
