wheel spacers
Old Oct 16, 2009 | 10:42 PM
andyb's Avatar
wheel spacers
I'm interested in getting wheel spacers on the rear axle of my Fit. My plan to to get the stock wheels flush with the fenders after lowering. I'm thinking of either 17 or 20mm.
Anyhow, does anyone know the thread pitch of the stock Fit lugnuts? I will need to get longer wheel studs so it would be helpful to know which thread pitch to get.
Thanks!
A
Old Oct 16, 2009 | 11:37 PM
FITMugen's Avatar
Bolt Pattern:4/100
Center Bore:56.1
Thread:12x1.5
I would not recommend spacer but adapter. Please see link below.
25MM WHEEL SPACERS ADAPTERS INTEGRA DEL SOL FIT CIVIC:eBay Motors (item 150364110444 end time Nov-03-09 16:51:10 PST)
Old Oct 16, 2009 | 11:54 PM
andyb's Avatar
Thanks for the link. I think the difference is semantic. Can anyone confirm that 12x1.5 is the correct thread pitch?
A
Old Dec 25, 2009 | 09:16 AM
Josephkao's Avatar
Is 25mm too big for stock 16" rims?
Old Dec 25, 2009 | 03:24 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
^ You need to change to an extended lugs, safest spacer you can run is 5mm the most on stock lugs IMO..
Old Dec 25, 2009 | 06:10 PM
petwhookie's Avatar
A
Yup 12x1.5
Old Dec 30, 2009 | 11:26 PM
Perrenoud Fit's Avatar
Smile Spaced Out
One of the things I've noticed is the wheel placment in the inner fender, it looks too far in. So I did some research and it was 50/50 the biggest fact was use a bolt on spacer and not a slide on over the studs. Retorque the lugnut (i'm going with 90 ft/lbs not 80) after driving for 2 days. MzFiT is gettin 25mm out back and 15mm up front, the wide track look. Ichiba has the best product with the V2 and I got all 4 corners for 240.00 shipped. If it puts the tires out to the fenders it'll do what i'm look'n 4 and save the price of new rims$. So when i do this i'll post before, during and after pix and see if it helps or hurts the handeling?................
C-ya'll
Old Dec 31, 2009 | 12:20 AM
solbrothers's Avatar
i ran spacers for a while. 25mm bolt on spacers. worked fine for me
Old Feb 25, 2010 | 09:58 PM
jookybanana's Avatar
run bolt-on spacers, they are easier to install than the ones with longer studs
i have 10mm bolt-on spacers on my rear and it doesn't seem flush yet, i think 10mm up front and 20mm rear will make the stock rims perfect
Old Jul 6, 2010 | 09:44 PM
hayden's Avatar
So, there is little risk of running a 7-10mm bolt-on spacer (not the adapter type) with the stock rear studs? Just want to confirm that since there are quite a few differing opinions on the matter.
Old Jul 6, 2010 | 10:16 PM
FITMugen's Avatar
If it is my car, I would not run > 5mm spacers unless I have a special long lug nuts. IMHO, wheel adapters are the way to go.
Old Jul 7, 2010 | 11:47 AM
alvarospatchez's Avatar
def go with extended lugs
Old Jul 7, 2010 | 05:27 PM
chrisng's Avatar
with my other car, i ran spacers, stock there was almost 7 revolutions of the lug nut wiht the spacers on it was like 4.5 its your call. just wanted to give some more info.
Old Aug 26, 2010 | 02:23 AM
y950129's Avatar
I'm looking to get some spacers too. I'm wondering if anybody has pics of spacers or adapters on the car. If u could share, that would be awesome! Still deciding on ???mm..... Is it better to do like 10mm front 20mm rear? or even out front and rear? Thanks in advanced for ur opinions!!!
o.... and can u also tell me stores that carry decent adapters???
Old Aug 26, 2010 | 06:44 PM
FITMugen's Avatar
You can see wheel adapters at my thread.
https://www.fitfreak.net/forums/2nd-...ort-mugen.html
I bought them from eBay for $85.
honda fit wheel adapters items - Get great deals on eBay Motors, Honda items on eBay.com!
cheffyjay
Jun 11, 2025 12:08 AM
Zillard
Dec 2, 2014 04:48 PM
research101
Aug 10, 2010 03:45 PM
diny01
Jul 8, 2010 10:58 AM
