Lets talk abour A/F ratio
Old Oct 18, 2009 | 04:21 AM
1990hondahf's Avatar
What are you guys running for you A/F ratios at:
  1. idle
  2. light boost
  3. full boost
Old Oct 18, 2009 | 08:00 AM
dewthedew's Avatar
13-15.x idle
10-17partial throttle
13 light boost
12.9 wot and now 11/10 in 3rd between 5-6500
I need a tune!I'll post after tune numbers lol
Old Oct 19, 2009 | 11:58 AM
explosivpotato's Avatar
Your AF ratio should depend on manifold pressure more than anything else. The fit uses a wideband, and the FIC can control it very well, so your AF ratios should be dead nuts as follows:
Idle / cruising (anything below 5-7" of vacuum) - 14.7-15.0 (I have mine running 15.0 for a hair better gas mileage)
Transition to boost (anything between 5" and 0) - AFR should smoothly ramp down to ~13 - 13.5 at 0 vacuum
In boost (anything above 1psi) - you should be running in the low to mid 12's.
Ignition is another story, I'm running a .68 degree/lb of boost step retard, with additional timing pulled in low RPM boost as this area tends to be a tricky one.
trinisir
Jan 20, 2016 06:01 PM
LuckyGD3
Feb 15, 2011 09:20 PM
Koi
Jun 24, 2010 02:55 PM
azkikersfit
Oct 26, 2009 05:30 PM
NIGHTHAWKSI
16
Nov 24, 2008 10:46 AM
