Anyone know how to install aftermarket speakers with an amp?
Old Nov 3, 2009 | 01:41 AM
mjohnsp's Avatar
So i recently have purchased some 6-1/2" Alpine Type S components to replace my front two speakers, and 5-1/4' Alpine Type R's for the back two, but have no idea how to go about this job or what to do about the factory mounting brackets. I want to do the job myself, about 6 months ago i installed a Pioneer Premier head unit, an alpine V-Power 450W mono amp, and a kicker L5. I have another Alpine V-Power 4 channel amp for the speakers, a rockford fosgate farad capacitor, and speaker wires. has anyone done this job themselves and have any tips/things to watch out for/ or even how to go about this at all?
Old Nov 3, 2009 | 03:41 AM
larshnordli's Avatar
I've never done this job myself, but if it is the 1st gen, the right way is to take off the whole door panels. I know there are a lot of guides in the I.C.E forums, so look there and see if you find any!
Hope this helps,
larshnordli
Old Nov 18, 2009 | 06:38 PM
5lilangels's Avatar
If you already have changed out the head unit, the speaker swap out should be gravy! Really crappy 6.5" speakers in each door. Just a couple of easy screws on the panels and a bit of trickiness with some clips and the door panels come right off. You have to make an "adaptor" of sorts to make up for the goofy factory sized speakers that you will be happily throwing away. I just used some rubber gasket material that I already had. Have fun!
Old Nov 22, 2009 | 08:23 PM
minitruckersfit's Avatar
just did the full job myself. Pioneer 6.5 components all around and alpine 4ch amp. Very simple job just time consuming.
1. screw holds on door handle then slide forward and unhook the bar.
2. pry the bottom arm rest out (3 clips) and it pops off
3. 3 screws behind the arm rest come out
4. unplug window harness
5. pry door panel off
6. Ran all new wiring from door, through the rubber, and to the amp.
Done!! All doors are the same.
I put my front tweets in the factory location and my rear tweets on the removable triangle piece above the back door panels. Hope that helped.
Old Jan 27, 2010 | 08:50 PM
danger69's Avatar
Where did you mount the crossover for the components?
craycraypixel
Aug 1, 2018 08:14 PM
Kdawgz
19
Oct 8, 2015 02:35 PM
1818orion
Nov 17, 2013 02:49 AM
mjohnsp
Nov 3, 2009 01:37 AM
Batman
Feb 4, 2008 06:34 PM
