Automatic Headlights
Old Oct 12, 2009 | 05:24 PM
cleif2000's Avatar
Has anyone installed a sensor to turn the headlights on automaticlly at night when the engine is running. I always seem to forget to turn on lights when it gets dark. All my other cars have a sensor in the dash. Thanks for your help. Leif
Old Oct 15, 2009 | 11:23 PM
Goobers's Avatar
I'd settle for the lights like the 1999.5 Nissan Pathfinder I currently drive.
Leave the switch in the ON position, and the lights are always on when driving around. The good part is... when you turn off the engine and open a door (or off engine + time), the lights go OFF.
Old Oct 16, 2009 | 07:58 AM
09blackfit's Avatar
I miss this feature about my volvo s40. It was called "home lighting" in their manual. You could set an amount of time up to 1 minute for the lights to remain on once you exited the vehicle to sort of light the way for you to safely make it to the house or whatever. Also, the same functionality was present as mentioned above with the pathfinder. You just left the lights in the on position all the time.
Old Oct 16, 2009 | 08:17 AM
09 Fit's Avatar
Are automatic headlights a feature on the FIT / JAZZ in non USA countries?
This is probably the feature that I miss the most.
Old Oct 16, 2009 | 09:26 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
yes they have them.
Old Apr 7, 2012 | 09:14 PM
martymcfly's Avatar
Old thread but I just came across this. There is an official Honda accessory called "Auto Light" for 2005 Honda Fit GD1 - part number 08V33SAD80091.
The control unit velcro on the dash next to the A pillar with an on/off switch. You can also adjust the sensitivity with a dial.
It should fit GD3 also.
- Tim
Old Apr 8, 2012 | 12:03 PM
CSM's Avatar
CSM
- Tim
Thanks. Do you have any more info on this such as a weblink? I was unable to find it with a search.
Carl
SilverEX15
Dec 15, 2014 11:03 PM
sissiromy
Sep 28, 2012 06:57 PM
ineedareed
Jan 31, 2008 11:30 AM
Steeldog
Dec 23, 2007 01:28 PM
RobVT
Jan 31, 2007 08:36 PM
