Quick easy TPMS Light Eliminator DIY!!!
Old Sep 20, 2008 | 01:50 PM
OrangeRevolution's Avatar
Originally Posted by D50boy
Anyone know if the TPMS is hooked up to any other system? I woldnt want the ABS system to be "disabled" or something because the car "thinks" that the tires are all flat. I hope it's just a dummy light.
On 2nd gen Fits, if the TPMS reads low, VSA defeat is disabled. In other words, VSA is 100% on.
Old Sep 21, 2008 | 05:55 PM
prufrock's Avatar
Our '09 Fit Sport is great, but that TPMS indicator has never gone off. The car is only a few days old. Does the dealer have to reset this?
Old Sep 21, 2008 | 08:14 PM
Rob22315's Avatar
Check the tire pressure first. Make sure they are all 32 PSI. It may take a little while for the light to go out, there is a minimum distance or speed necessary to get the lights cleared. I forget if it is miles or speed but the number 23 comes to mind. Other TPMS threads have more info.
Dealers leave the tire pressure low sometimes to give a cushy ride on test drives.
Old Sep 21, 2008 | 09:47 PM
prufrock's Avatar
Thanks for the advice. I just checked all 4 tires, and they were all at 40 PSI. I'll wait until I drive it around for a day or so to see if the computer recalibrates the data. I did think that my original ride was a bit harsh. I now also question WTF is going on with the dealership in terms of the final out-the-door check of its cars. Luckily, I only had 3 miles on my odometer; therefore, somebody didn't have enough time to screw anything else up....
Old May 3, 2009 | 08:04 PM
awptickes's Avatar
I just did this in my 2009 base. It was almost the same procedure. Probably the hardest part was positioning the tape properly, heh.
But, to ease my troubled mind, I now keep a gauge in the car (As I do in my civic):
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
Old Jun 12, 2009 | 08:25 AM
megumi's Avatar
Tpms light!!! Ughhhh
I've taken my car two the dealer 3 times!!!!!!!! the freaking light wont go off!!!!!!!!! I'm going to flippp!!!! anyone have any suggestion other than checking tire pressure or broken sensor??? oh this started happening after i took my car to walmart!!! never go there not even for new tires they mess with your car put wrong parts!!! Walmart made my tpms light come on!!
Old Jun 12, 2009 | 08:28 AM
awptickes's Avatar
Which light is on? the one that is the exclamation point inside a tire, or the letters TPMS?
Have you tried taking it back to walmart and speaking with a manager?
Old Jun 12, 2009 | 12:21 PM
Rob22315's Avatar
1. Check your tire pressure in all tires. Walmart and the dealer may have left it low.
2. You have to drive the car a minimum of 23 miles IIRC for the light to go out once everything is reset.
3. Walmart may have clobbered one of the sensors, did the dealer check that all sensors were operating? If one is broke, get Walmart to fix.
4. Find a new dealer.
Old Jun 14, 2009 | 12:16 AM
RichXKU's Avatar
Did you check the spare? Ran into that with an 07 Rav4. All 4 tires were perfect but the spare was low.
Old Feb 20, 2010 | 09:18 PM
apexanimal's Avatar
bump for me... link doesn't work anymore...
Old Apr 9, 2010 | 07:28 PM
chrisng's Avatar
bump! how does this work?
Old Apr 9, 2010 | 09:19 PM
  #32
dewthedew's Avatar
werd, i need todo this but link is dead
Old Apr 15, 2010 | 11:15 AM
  #33
apexanimal's Avatar
i pm'ed him... you basically raise the gauge cluster and tape over the light...
Old Apr 15, 2010 | 12:14 PM
  #34
chrisng's Avatar
^ any links on how to do that? the tape won't mess up the light? how long did it take?
Old Apr 15, 2010 | 12:22 PM
  #35
chrisng's Avatar
Instrument Visor Removal/Installation
found this but the pics don't work for me. worked on google chrome. firefox wasn't working for some reason
Old Jul 12, 2010 | 05:59 AM
  #36
mgutt's Avatar
Originally Posted by SHG_Mike
Not sure quite where this should go but there are many TPMS light issues here so i figured this would be best.
I finally thought of a quick easy NON permanent way of getting rid of the annoying TPMS light. The full write up can be found here
TPMS Delete
Offline
Old Jul 12, 2010 | 11:22 AM
  #37
chrisng's Avatar
any updates on this?? i really want to do this!
Old Jul 12, 2010 | 12:35 PM
  #38
dewthedew's Avatar
im pretty sure he pulled the cluster apart an put black tape inside
Old Jan 3, 2011 | 11:02 PM
  #39
SHG_Mike's Avatar
Yea sorry guys I very rarely frequent this site anymore. This site i had it on has sense been dead for awhile. All you do it remove the cluster, remove the clear lens of the cluster, it just has some push tabs to release, then put some e-tape over the square for the TPMS light. Pretty basic
Old Jan 15, 2011 | 11:59 PM
  #40
grtpumpkin's Avatar
Once you have the cluster out of the dash you can remove the clear plastic piece. With that out of the way you will find that the gauge faces are just a thin plastic overlay that isn't glued down. Just lift up on the gauge faces enough to get a piece of electrical tape over the LED for the TPMS indicator and you are set. Just be careful how large a piece of tape you use, I covered up my right turn signal by accident and had to undo the whole thing to fix that.
Sloto200
Mar 28, 2015 09:50 PM
tin
Dec 4, 2011 10:42 AM
jetscream
Jul 25, 2008 12:16 AM
Pursang
Mar 31, 2008 06:41 PM
percy
Dec 10, 2007 03:37 PM
