popping please help!!!
Old Oct 4, 2008 | 03:48 PM
AtticusFit's Avatar
ok so just install a set of skunk2 pro c coilovers on a fit a, we are getting this popping sound coming for the passenger front side. i ve contacted skunk2 they said to put some grease on the top and bottom of spring so we did and the sound is still there. i can look up there while car in pn the ground and see the spring popping on the upper cup i believe... any suggestions???
Old Oct 4, 2008 | 03:52 PM
solbrothers's Avatar
tie rod issue. i have it too
Old Oct 4, 2008 | 03:54 PM
AtticusFit's Avatar
no tie rod is fine.. i see the spring makeing the noise at least it seems that way.
Old Oct 4, 2008 | 04:11 PM
DOWNTYM's Avatar
When i put my progress springs on i had a clunk/pop from the passenger front to. . . Just twisted the spring and it went away.
Old Oct 4, 2008 | 08:16 PM
redrumm's Avatar
damn that sucks.
take it out and reinstall it or take off your tire and jack it up
Old Oct 4, 2008 | 08:53 PM
JDM_DOHC_SiR's Avatar
Also check the strut bearings at the top of the shock..
Old Oct 4, 2008 | 11:26 PM
GD3_Wagoon's Avatar
ooh i had the same problem
kenchan suggested adding more preload to the spring and tightening the nut at the top of the strut holding the spring hat down. NO MORE NOISE
Old Oct 5, 2008 | 06:36 PM
Fit4Trav's Avatar
^^Try this!!!
I had this sound when I installed springs on my xB. The top strut nut wasn't tightened all the way. Re-installed with more spring load and walla no more sound =)
Old Oct 5, 2008 | 08:44 PM
AtticusFit's Avatar
Originally Posted by Fit4Trav
^^Try this!!!
done both today and the same????
Old Oct 5, 2008 | 10:23 PM
Darkstars's Avatar
are you sure the bearing the strut top is there? not sure how the Skunks install but make sure the bearing is there. If its there and seated right replace the strut mount/bearing. When the bearing binds up the spring pops when you turn back and forth.
Old Oct 5, 2008 | 10:30 PM
AtticusFit's Avatar
yep...bearing is there..
pearl
May 27, 2011 05:38 PM
jmag310
Mar 5, 2011 05:48 AM
07fitsport
Apr 19, 2008 02:26 PM
t3chn0rav3rb0y
16
Mar 28, 2008 03:52 PM
saiko
Mar 12, 2008 03:24 PM
