Better replacement caliper?
Old Jun 17, 2009 | 11:09 PM
im the fit's Avatar
Has anyone found out if theres a better caliper same size as stock?
Old Jun 18, 2009 | 12:59 AM
Texas Coyote's Avatar
I am leery of installing different pads or callipers unless also installing an adjustable pressure valve to moderate pressure..... I don't drive in competitive events and am pleased with the way mine works as is..... I would think that if brake fade is a problem, it would be on the rear drum brakes.
Old Jul 9, 2009 | 02:38 PM
nttdemented's Avatar
The guys at Wilwood can probably help you select a caliper that should be a direct replacement for our cars as our calipers are shared with other cars such as RSX (base model) and some older civics. I've been meaning to call them to see if they have a dynalite caliper that drops in to replace the current one keeping stock-sized rotors.
Old Jul 15, 2009 | 10:27 AM
Jodele's Avatar
I just got Acura Integra Type-R calipers...they bolt up to the stock ears. The stock disc is 262-mm X 21-mm. The Type-R discs are 282-mm X 23-mm, but 25-mm discs will fit. This conversion needs the 282-mm discs. I will be posting the install with part numbers.
Old Jul 19, 2009 | 09:01 AM
Jodele's Avatar
Check out my new thread on this install
https://www.fitfreak.net/forums/fit-...tml#post700243
Shora
18
Apr 26, 2012 11:19 PM
thewatcher101
Jan 23, 2012 06:22 PM
astig
Oct 7, 2009 04:00 PM
FELIXY69
19
Jul 19, 2009 09:22 AM
JDM_DOHC_SiR
Dec 8, 2006 03:58 AM
