GD3-Fits' Question of the day 2
Old Jun 3, 2008 | 04:30 PM
GD3-Fit's Avatar
I <3 SPOON
Hey guys,
If i run a header, stock cat, and full exhaust will i have to worry about the a/f ratios leaning out or will i be ok?
Also, i saw in a thread a while ago someone just 'plugged and played' a set of 310cc injectors?
Correct me if i'm wrong but don't you need a tune if you do that?
I'm not very good when it comes to tuning and engine management.
Thanks,
-Ricky
Old Jun 3, 2008 | 04:48 PM
JDMchris.com's Avatar
I run THIS
Originally Posted by GD3-Fit
Hey guys,
Thanks,
-Ricky
you should be ok running that setup. 310cc is WAY too big for just a NA setup with H/E.... and yes you would need to tune it.
Old Jun 3, 2008 | 04:59 PM
koolkevin1107's Avatar
ur fine with the A/F ratios. That's what i'm running and my A/F gauge is showing no problems with it being to lean.
Old Jun 3, 2008 | 08:20 PM
greekdaddy000's Avatar
agreed, shouldn't be a problem
Old Jun 4, 2008 | 08:56 AM
GD3-Fit's Avatar
I <3 SPOON
thanks every1
Old Jun 5, 2008 | 07:06 PM
GD3-Fit's Avatar
I <3 SPOON
one more question.
are 205cc injectors plug and play?
i mean the ecu is not originally programmed to use bigger injectors so if they were added would the ecu ignore that the injectors can provide more fuel? just curious.
-Ricky
Old Jun 5, 2008 | 07:08 PM
I run THIS
same thing if you add the 310's.... not needed...
Old Jun 5, 2008 | 07:13 PM
GD3-Fit's Avatar
I <3 SPOON
ok thanks chris!
-Ricky
Old Jun 5, 2008 | 07:29 PM
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
the only injector upgrades around are (as far as i know) available through Kraftwerks, and are only for use in conjunction with their supercharger kit. You should check it out
Old Jun 6, 2008 | 03:53 PM
GD3-Fit's Avatar
I <3 SPOON
thanks i'm not a newb i'm on this site everyday
i was just simply asking a question about slightly larger injectors and how that would react with the stock ecu.
-Ricky
bdogpot
Aug 21, 2012 03:50 PM
BigTuna_GD3
Nov 26, 2010 11:43 PM
Loevess
Sep 21, 2010 02:04 PM
Loevess
Sep 20, 2010 03:23 PM
evo9tofit?
Feb 1, 2010 06:07 AM
