Rear wiper during reverse
i recently purchased my fit and found that when i'm in reverse my rear wiper starts. seems like an odd thing to happen, considering a dry wiper blade on a dry window can be destructive. is this normal, or is mine tweaking out?
It shouldn't happen every time you turn on you front wipers either. I can turn my rear wiper on independently of the front.. I never use it, but I think I just twist the end of the wiper switch for the rear and move the wiper switch down for the front.
Sounds like there's some crossed wires, I'm guessing the wiper is wired up to your reverse lights somehow.
Is the Fit new or used?
I think the car is programmed that way, if you are clearing your front window, your back window probably needs it too. Like in the rain when the car has been outside.
I also don't like it, because my rear window is often dirty, and I don't want the wiper scratching the glass. It's a drag having to remember to turn the front wipers off before backing up.
Mine too
Mine too but my front wipers are broken too- not turning off so lever pushed all the way down! Strange!
VanIslFit
10-05-2008 12:51 AM
