Racing A place to discuss upcoming and past Fit racing events.
Autocrossing GD3 in STF
Old 05-25-2014, 02:19 AM
Rollerboots666's Avatar
San Diego, CA 6/1
El Toro, CA 6/8
Anyone going to either of these?
  #42
Old 05-27-2014, 03:31 AM
Originally Posted by Previc93
Yes abs... but I didn't know you were just learning. Keep it on so it will help u feel when you pushed the pedal too hard. The like the other guy said release the pedal and press again. You will learn how to modulate the pedal.
I trail brake all the time to help the car to rotate. And if you do that with the abs on it will go into abs braking because it is sensing wheel slip even though it may not be slipping. My inside rear tire lifts on turns and if I barely tap the brakes that wheel will stops.
Is the ABS on the fit electronic? Can it be turned off by a fuss or would I have to manually disengage the whole unit?
  #43
Old 05-27-2014, 03:36 AM
Previc93's Avatar
Yes it is electronic. You can disconnect the fuse or just unplug the module. Either way is fine. Your brake and abs light will turn on. It's normal.
  #44
Old 05-27-2014, 10:59 PM
Thanks Previc93. Curious how this will feel when racing.
  #45
Old 05-27-2014, 11:00 PM
Does anyone know if you can have a CF hood or hatch in STF class? Didn't see anything in the rule book or maybe over looked it.
  #46
Old 05-27-2014, 11:17 PM
TPColgett's Avatar
You can only have factory original installed body pieces in any ST class.
What's tough with the SCCA AutoX rules is that unless it specifically says you CAN do something, then you cannot do it...
Now, "locally" small clubs can allow whatever they want, but remember anyone competing in the same class can protest your CF/aftermarket aero
  #47
Old 05-28-2014, 02:18 AM
Yeah that's what I figured.
  #48
Old 05-30-2014, 07:36 PM
FitFlowjoe's Avatar
Glad to see a bunch of folks autocrossing their Fits... I'm gonna have to try that ABS fuse trick, because man does that irritate the crap out of me.
Also guys if you plan to run 225's, I HIGHLY recommend race pads if your keeping oem size rotors.
  #49
Old 05-31-2014, 12:16 AM
I'm gonna stick with 205 for this year. Also because thats the wide Bridgestone makes. Since I work for Bridgestone I wanted to try out the RE-11A's for AutoX. This is my first year and they work great so far.
I've already switched to race pads and rotors. Curious to see how the non-ABS works.
Aussie
07-20-2018 12:44 PM
arrow_runner
08-06-2015 03:09 PM
Seryoga1
11-28-2010 10:46 PM
GD3_Wagoon
01-31-2009 05:00 PM
Hondasforlife
04-10-2008 03:19 PM
Quick Reply: Autocrossing GD3 in STF
