Starter noise elimination trick
Old Oct 9, 2019 | 03:52 PM
doctor J's Avatar
Thumbs up Starter noise elimination trick
Assuming that this noise is caused by sticking starter solenoid after cold soak, you may try to momentary blip the key into the start position and release it quickly (without actually letting starter to spin). In theory, the heat generated in the solenoid coil will warm up the gummy grease between the solenoid plunger and thin wall brass bushing and hopefully allow grinding free start after that (this will not work if starter grinds after EVERY start).
Please try it out and post the results!
Old Oct 14, 2019 | 10:56 AM
Jared592's Avatar
Interesting. You have any luck thus far with this strategy?
Old Oct 14, 2019 | 02:20 PM
doctor J's Avatar
On my car it happens only with temperature below upper 40s.
So this can only happen around December.
I'll probably install my replacement starter before this time
Old Nov 18, 2019 | 11:09 AM
Jared592's Avatar
FYI: Been trying this and it doesn't seem to help, even if I blip it a few times before actually trying to start (I only get the grind after overnight cold soak).
Old Nov 18, 2019 | 12:49 PM
doctor J's Avatar
Thanks for the feedback.
This probably rules out "sticking solenoid' and points to planetary gear issue/output shaft slop (worn bushing in the starter nose)
Old Nov 18, 2019 | 01:19 PM
Jared592's Avatar
Sure thing, I figured you'd want to know how it worked out.
Old Dec 4, 2022 | 03:35 PM
Breezer's Avatar
I've tried this, and it makes no difference.
Old Dec 6, 2022 | 11:15 AM
doctor J's Avatar
If noise is present right after start, with key in start position, the worn or sticking overrunning clutch is a problem
Old Nov 11, 2023 | 11:38 PM
cirpili's Avatar
Overrunning clutch
Have you tried replacing just that part? It looks almost as expensive as a remanufactured starter.
doctor J
Jan 31, 2021 05:31 PM
doctor J
Sep 30, 2019 12:02 PM
doctor J
Feb 20, 2019 05:55 PM
DCTepper
Nov 22, 2013 07:41 AM
ftlmatt
Jul 18, 2010 11:58 AM
