I’m a newbie here. Just bought a fit and already loving it. The ignition needed to be replaced so I got a used one with a key. Unfortunately it’s different, the ignition that was already installed requires only two plugs to be plugged in, the replacement one I got requires 3 plugs to be plugged in. Is someone able to help me out with what 3 plugs need to plugged in to the replacement ignition and the car starts with just the brown big plug plugged in so is that good enough or would I run into trouble later on?
The ignition that was already installed in the car The replacement I got
Thanks for the help in advance.
