View Poll Results: Injector or ignition problem?
ignition
100.00%
injector
0%
Voters: 2. You may not vote on this poll
Missing at Idle only
Old Jan 3, 2020 | 03:47 PM
FritzH's Avatar
My 2007 Fit with 190 k miles misses at idle. There is no check engine light. I don't think it is a coil pack, as it runs just fine under load during acceleration, normal running and at engine speeds above 1200 RPM (in neutral sitting still). I have run a bottle of Techron in two tanks of gas. Both times it cleared up with the Techron treated fuel. The problem then returns when I go back to straight fuel. My guess is that there is a sticking injector causing a misfire on one of the cylinders. Any ideas before I change out the injectors? Has anyone else experienced this?
Old Jan 8, 2020 | 08:44 PM
mxl180's Avatar
It's either beginning of coil failure and or valve adjustment. If I recall my early coil replacement symptoms were idle misses at red lights, then later it started getting misses on highway. Valve adjustment fixed my rough idle on cold startups.
Try these $6 coil replacements https://www.autozone.com/ignition-tu...58986/193447_0
If you have shoprunner it'll give you free shipping.
Old Jan 8, 2020 | 08:46 PM
GolNat's Avatar
I would start with a valve adjustment. They usually need it by 100k
Old Jan 9, 2020 | 02:06 PM
FritzH's Avatar
Thanks, It doesn't miss when cold, only after it has warmed up a bit. I will try adjusting the valves as that is cheap and probably needs it anyway. First law of mechanics, "start with the simple things first".
Old Jan 16, 2020 | 06:48 AM
giwdly's Avatar
Check your coil packs, my CEL didn’t read anything until I was only using 3 cylinders while driving
inkeye
Nov 3, 2016 06:37 PM
gsarmedic
May 27, 2016 07:29 PM
Flyboybob
Oct 3, 2015 09:29 PM
UnicycleWheelie
Mar 8, 2014 11:28 PM
gfrobe
Dec 19, 2012 03:58 PM
