No reverse gear manual transmission
Old Apr 24, 2020 | 11:51 PM
EnragedPenguin's Avatar
Hello there! I just picked up a new to me 2007 Honda fit sport with the manual transmission on the cheap because it doesn't go into reverse! I drove it home with no issues as all of the forward gears work great. Car does not go into reverse with the vehicle on or off. To clarify, physically the shifter cannot be moved into the reverse position, even after applying a good amount of force to it. I've removed the air filter setup as well as the battery to get a better look at the top of the trans, and even manually moving the shifter from the top of the trans it will not physically engage into reverse, so I don't think it's a bad linkage or something along those lines. Anything else I can try to get reverse to work before I start pulling the transmission out and looking for a replacement? Thanks in advance for any suggestions and comments.
Old Apr 26, 2020 | 03:39 PM
doctor J's Avatar
Broken or jammed back-up light switch?
Old Apr 26, 2020 | 11:11 PM
Thanks for the suggestion! I pulled the back up light switch out of the transmission completely and it still doesn't go into reverse. I assume that means the switch is good? Thanks for the reply!
Old Apr 27, 2020 | 09:52 AM
doctor J's Avatar
Here is the page from manual how to check the shift lever clearance. if good, the transmission has to be pulled of the car
Old May 12, 2020 | 11:55 PM
Got the old transmission out, and diagnosed at a transmission shop. Something was worn on the 5th and reverse gear and needed to be replaced. Quoted $1150 CAD for replacement, so ended up getting a junkyard transmission for $500 CAD instead. Just in the process of buttoning up everything now. Just curious if you can reuse the axle ring clips or should order replacements? The driveaxles go in and stay in firmly but just curious as I don't want to buy new axles in a month. Thanks again!
Eric Satoshi Harima
Apr 13, 2019 03:28 PM
Spartan_1337
Sep 6, 2018 10:53 AM
chubbs899
Oct 22, 2014 04:37 PM
8strung
Aug 15, 2014 02:49 PM
mole177
Sep 23, 2008 12:13 AM
