Runs Bad
Old May 24, 2020 | 03:18 AM
Jim Bailie's Avatar
Runs Bad
Trying to keep my 2002 Honda Jazz on the road for as long as I can, of late it is running like a dog, it jutters & jerks & accelerates bad, like it's not getting enough fuel. Anyone any ideas. I am not a mechanic but will tackle most jobs.
Old May 29, 2020 | 04:25 AM
BugsIsOnDrugs's Avatar
Do you have a check engine light, and if so did you scan for codes? It's hard to diagnose something just like that. Could be the fuel filter clogged up or the fuel pump dying if you are sure about the fact that it's not getting fuel. Could also be a coil on plug failing, running on 3 cylinders instead of 4 will jerk the car for sure when accelerating (A tester is cheap). Check on dumb things first like your spark plugs gap, they can stop sparking all together when the electrodes gets too damaged.
Last edited by BugsIsOnDrugs; May 29, 2020 at 04:27 AM. Reason: re-phrasing so it's more like real English lmao
Ridza
May 6, 2016 05:48 AM
Chris Nicola
Nov 28, 2012 10:07 PM
kryzt_02
Jan 5, 2008 10:47 PM
pappiccio
Dec 9, 2005 01:28 PM
ahcow
Oct 25, 2005 12:47 AM
