Acura rims on my fit?
Old May 30, 2020 | 03:26 PM
Sean McKenzie-Mardelli's Avatar
Could someone please tell me if these rims would be compatible with my 2007 Fit Sport? The OEM tires were 195 55/r15, same as the ones in this listing. However, I know that when it comes to rims, you need to worry about complicated codes likes: 5.5JJx14 ET45, THD, CB, offset and a bunch of things I don't understand.
These are the wheels with tires that I'm interested in purchasing: https://www.kijiji.ca/v-tires-rims/m...ale/1499084603
Old May 30, 2020 | 07:38 PM
Rob H's Avatar
As long as they are 4X100 bolt pattern you should be fine
Old Jun 9, 2020 | 05:11 PM
nuocmumracing's Avatar
offset will be wrong.. but seriously why does the fit have a 55 offset?
Old Jun 10, 2020 | 12:31 AM
TnTkr's Avatar
Wheel offset is part of suspension geometrics and Honda has designed it that way. I assume they wanted to bring the wheel hub as much out as possible to make the structure space efficient. I assume they did not want to bring the wheel any outer to keep safe distance between tyre and fender, which is a needed to prevent damage when there is mud, ice or other debris inside.
Old Jun 10, 2020 | 04:28 PM
slave's Avatar
These are from Acura EL. I cannot find Honda center caps anywhere to replace these.
fitjoe
13
May 11, 2013 12:17 AM
EMC2
Oct 31, 2012 10:47 AM
EMC2
Jul 23, 2012 01:34 AM
kdean101
Feb 14, 2009 09:53 AM
unphit
Feb 20, 2008 10:45 PM
