2007 clutch replacement
Old Aug 27, 2020 | 12:10 AM
Rusty43's Avatar
What’s the trick to pulling axles out of transmission? Really tough to get prybar behind inner joint
Old Aug 27, 2020 | 01:50 PM
Ryan Hendrickson's Avatar
I used a 12-inch pry bar from Lowes. https://www.lowes.com/pd/Kobalt-Pry-...ng-Bar/4777017 It's pretty thin on the one side, so I was able to get just a corner in and pop it out.
Old Aug 27, 2020 | 04:56 PM
Rusty43's Avatar
Thanks. Just a circlip for retention then?
Old Aug 27, 2020 | 05:02 PM
Yea, just a circlip. Also, be prepared for a little transmission fluid to drain out too. When I recently pulled mine I had some drip/drain out, although I'm not sure if I was a little overfull, or if the car was at a tilt.
Old Aug 27, 2020 | 08:48 PM
Rusty43's Avatar
Do I need to drop subframe to remove rear trans mount?
Old Sep 20, 2020 | 12:09 PM
rauelius's Avatar
I came across this.
AKAgeorge
17
Jan 4, 2017 12:01 AM
Rossi
Apr 26, 2016 10:16 AM
Niki4os
Feb 1, 2015 07:49 PM
tduffy
Jul 27, 2013 05:47 PM
gettinafit
15
May 17, 2006 12:22 AM
