AC hit and miss ... works first 3-5minutes of Car ride than diies
Old Aug 31, 2020 | 10:50 PM
Dj365's Avatar
I have fit/jazz 2007 . AC kicks in and works fine first 3 minutes of ride than dies off. Very noisy when working... Puzzled where to start!
Old Sep 2, 2020 | 10:43 AM
Azuki's Avatar
First don’t run it anymore if you can avoid it. If it was blowing warm, it means it’s empty of refrigerant and most likely will get damaged.
#1 check AC clutch pack. Hopefully that’s all it is. If he compressor is blown, which happens, it’s approaching a thousand dollars in repairs at a shop. It’s a few hundred for a compressor with clutch pack, then the service cost. If you choose to do it yourself, please purge the refrigerant responsibly!
Old Sep 2, 2020 | 11:16 AM
Jared592's Avatar
If you get cold air for any length of time, your issue is not empty refrigerant, but either the compressor clutch relay or the compressor clutch and field coil themselves.
Check out this video:
As an aside, attempting to run the AC with empty refrigerant won't harm anything, as the compressor requires a minimum amount of pressure in the system to run. This is governed by the AC pressure switch. If it's too low or too high, the compressor simply won't run at all. No harm.
Old Sep 2, 2020 | 05:15 PM
Azuki's Avatar
Check out this video: https://www.youtube.com/watch?v=oIm979qT-5c
Good to know about the pressure switch, that's why we weren't hearing anything when the A/C went. Thanks for the info learn something new every day!
wetto
Jul 8, 2020 08:47 PM
Grant Wertheim
Jun 17, 2020 03:50 PM
redludesh
Jul 22, 2018 02:20 PM
Jay Pee
Feb 2, 2018 03:13 PM
strepto
14
Jan 20, 2006 11:18 AM
