100,000 Miles
Old Nov 17, 2020 | 11:58 AM
DanMarino's Avatar
100,000 Miles
My 2008 Honda Fit Sport just rolled over 100,000 miles last weekend. I have a few questions for everyone about my maintenance plans.
1. I plan to adjust the valves. How difficult is this? I have adjusted valves and done head gasket jobs on my previous 1992 Volvo 240. I also adjusted the valves on my daughter's 2001 Honda CR-V. Is the valve adjustment pretty straightworward?
2. I am used to changing timing belts and water pumps. However, this Fit has a timing chain. Do I just wait for the water pump to fail before changing the water pump? Also, how difficult is this job?
3. If the water pump should be changed, I'll change the coolant and serpentine belt as well.
Car is currently running perfect. Only problem is the warning light for the tire air pressure monitoring system.
Thanks for everyone's thoughts.
Old Nov 17, 2020 | 02:38 PM
GAFIT's Avatar
Congrat's on hitting 100k!
My suggestions are below...
1. I plan to adjust the valves. How difficult is this? I have adjusted valves and done head gasket jobs on my previous 1992 Volvo 240. I also adjusted the valves on my daughter's 2001 Honda CR-V. Is the valve adjustment pretty straightworward? - Very straightforward. You will want a set of bent feeler gauges and a tube of gray "import" silicone. Other than that, just standard hand tools. If done slowly, it will take about 3 hours. Suggest changing spark plugs at the same time. Only use NGK or Denso Iridium plugs.
2. I am used to changing timing belts and water pumps. However, this Fit has a timing chain. Do I just wait for the water pump to fail before changing the water pump? Also, how difficult is this job? - I see no reason to mess with the water pump. Our Fit is super close to 200k miles and haven't changed it yet. Car still runs cool.
3. If the water pump should be changed, I'll change the coolant and serpentine belt as well. - I would change the coolant and belt, but not the pump. Belt is adjusted old school. No tensioner on the GD.
Car is currently running perfect. Only problem is the warning light for the tire air pressure monitoring system. - batteries probably died in the sensor. Only new sensors will fix the problem. I went with Denso sensors from RockAuto and had the dealer program them to the car.
Old Nov 18, 2020 | 08:59 AM
DanMarino's Avatar
GAFIT, thanks for the great reply.
Old Nov 19, 2020 | 10:06 AM
doctor J's Avatar
Will add some recommendations
Assuming you have an instruction which tells you that the engine must be below 35 degrees C while doing this procedure and the number one cylinder is the one closest to the timing chain,
Here is the list of tips:
1) turn the right front wheel to the right; this will allow better access to the crank bolt
2) the engine requires minimum effort to rotate; the spark plugs can stay in place unless you plan to change them. The lower intake stays on the engine. I removed plenum part only, while leaving throttle body in place connected to the coolant lines
3) at this mileage /age many rubber items can go bad So get the valve cover gasket (gasket only, grommets are not contacting oil and will not cause oil leak; invest in factory gasket, Felpro brand I used had a tab molded in opposite way
Part number is clear enough
Additional items: plenum gasket, (2 required) and throttle body gasket (sold as fuel injection gasket or even carburetor base gasket); Beck-Arnley is the best brand in terms of fit; also grommet and PCV fresh air hose
Air cleaner grommet (upper right) and fresh air hose (partially obscured by "harness bracket" text) may need replacement
4) if possible pull the Intake Air Temperature Sensor out of the air cleaner housing instead of disconnecting from the wire , otherwise be prepared to clear the code.
5) use flat 3/16" wide screwdriver with "thick" blade edge to prevent damage to the set screws, also use 10 mm box offset wrench and "bent" feeler gauge set.
Water pump bearing showed no play on the car with 154k; coolant had to be replaced at after 10 years back in 2018
Use genuine serpentine belt; it has cross hatch back which prevent scratches on the rollers and minimizes glazing and squeal compared to after market smooth back belts; the idler roller bearing may need replacement as well. Napa sells replacement bearing (SKF bearing is the best)
Old Nov 19, 2020 | 10:17 AM
GAFIT's Avatar
4 Valve adjustments and a cam swap that required full disassembly and still haven't used a single gasket on our Fit. Zero leaks. We're lucky though and live in the South where everything stays clean and the seals aren't subjected to extreme temps.
I choose to remove the coolant lines from the throttle body and leave it connected to the intake. I remove the air box lid all the way to the upper intake/lower intake connection as one large assembly. The coolant lines can be a pain though so I could understand either method.
Honda was fantastic with these motors. Every gasket is reusable except the head gasket. All others are very high quality. Ours is still drum tight with zero seepage at near 200k miles.
I do have a full gasket set plus some duplicates for the car though. Just keep looking at them when I take it apart and see no reason to change. They all still look like new and are sealing tight.
Old Nov 19, 2020 | 11:07 AM
DanMarino's Avatar
Thanks to both of you for the great responses. I'll let you guys know how it goes. I'll likely do the job sometime in December or January.
spin out
Jun 22, 2019 11:59 PM
OrangeSport09
Oct 24, 2018 12:15 PM
tdot
Oct 17, 2013 01:42 PM
Kenny
May 4, 2005 04:44 PM
mpet500
May 4, 2005 11:16 AM
