08 with auto transmission P0847
Old Jun 14, 2021 | 04:43 PM
Gmader2001's Avatar
Hi everyone. I have a 08 Fit with auto trans and the engine light came on with the flashing D, also wouldn't shift into higher gears. The codes where P0847 and P0756. I changed the 3rd gear pressure switch with a genuine honda part and now the flashing D is gone, the P0756 is gone and the car shifts through all gears but the engine light is still on with P0847 and won't reset with a scanner. Is there something I'm missing or does the car need to drive a bit for it to reset? Thanks for any input.
Old Jun 14, 2021 | 11:34 PM
doctor J's Avatar
Have you changed switch on the radiator side?
Persistent code can be if there is an intermittent short in the wire between the transmission fluid pressure switch B (3rd clutch) and the PCM
or the switch is rated for different pressure (aftermarket)
From 2017 3rd gear switch is the same p/n as the second gear switch
Old Jun 15, 2021 | 12:06 AM
Gmader2001's Avatar
The switched i changed was right by the dip stick. I bought the part at Honda I believe this is an updated part then what was on there originally
Vonn
May 20, 2021 10:30 AM
JessiM
Dec 1, 2016 09:18 PM
Fieldstone
Sep 30, 2016 07:37 PM
geepondy2
Jan 14, 2012 09:12 PM
AtticusFit
Mar 9, 2010 07:33 AM
