Even w/ AC off, compressor kicking on/off rapidly
Old Jul 6, 2021 | 03:18 PM
TheGolfFather's Avatar
2007 Fit; Recently replaced my factory compressor and condenser due to a leaky compressor and failed compressor clutch. A/C now blows ice cold and all things seem great while it is on but whenever I turn off either the fan (to zero) or press the A/C button OFF the compressor clutch starts short cycling like crazy. The clutch clicks on and off every second and I can hear the condenser fan pulsing at the same rate. I checked both relays and they are fine. Does anyone have an idea what could be causing this? The system was refilled with 14oz of refrigerant.
Could there be air in the system? Maybe a bad pressure sensor?
It seems odd it does this when the compressor is off and leads me to believe it is an electrical issue.
Thanks for your replies..
Old Jul 10, 2021 | 05:55 PM
doctor J's Avatar
Check the following items
1) Incorrectly wired thermal protection switch on the compressor (grounded blue-white or white-blue wire(s)
2) A/C switch
Old Jul 12, 2021 | 02:36 PM
Thumbs up
2) A/C switch
Thanks for the suggestions, the original compressor was doing the same thing (albeit without the clutch engagement sound- fan pulsed just the same) so I don't think it is the compressor wiring. I did just order a new A/C switch and will report back after I receive and install it
Dj365
Sep 2, 2020 05:15 PM
fittiestfittyfit
Jun 28, 2020 09:23 AM
dwtaylorpdx
Jul 26, 2017 11:03 PM
gahris
May 14, 2017 04:51 PM
MorganKl
Jul 1, 2013 01:49 AM
