Stuck rocker arm code p2646
Old Jan 29, 2022 | 11:19 PM
ndub's Avatar
I got this code, went to a mechanic paid them 170 to do a diagnostic, they told me I needed a new spool valve solenoid. I made this repair. Was a $220 part. But the code is still on and my engine still bogs down when accelerating. This did not fix the problem at all. What can I do? The car is an 07 Honda Fit sport automatic
Old Feb 2, 2022 | 02:22 PM
JUSA4BANGER's Avatar
I've been fighting this code for almost a year now. I ended up buying a new vtec solenoid and it fixed it for a bit. The thing is, my motor is VERY worn and eats oil. So the screen on the solenoid gets clogged pretty quick. So I have been having to clean the screen and change the oil quickly than usual (3,500 miles).
So if you have a new solenoid, here's what I would look at.
1) Oil is clean
2) Clear Code
3) Screen on solenoid is clean
Old Feb 7, 2022 | 05:34 PM
doctor J's Avatar
Probably won't work on Fit, but just punching the screen (yea) worked on Prelude .
The car has been a piece of junk anyway.
Old Feb 7, 2022 | 11:43 PM
MUDKIP's Avatar
I would check the wiring and the oil pressure switch from what I found searching.
If you wanted to test the solenoid itself, another member said this in an old thread; "Does solenoid click if you apply 4.5 volts to is terminals?"
Old Feb 14, 2022 | 12:02 PM
ndub's Avatar
Keeps breaking
I replaced the solenoid and oil but seems the piece keeps breaking. The brand is duralast
Old Feb 14, 2022 | 07:51 PM
MUDKIP's Avatar
I would try a different brand, if possible, as some new parts can be faulty out of the box. Also, that seems a little overpriced but I assume it's warrantied.
tbearfit
Jan 24, 2022 11:28 PM
FITDragon
Nov 11, 2021 09:08 PM
drkatherine1
Mar 27, 2017 09:52 PM
harlen
Mar 6, 2009 05:37 AM
