12.7 Gallons in my 2008 fit (10.8 gallon spec)
Old Feb 25, 2022 | 09:49 PM
tealeaves's Avatar
I just filled up my 2008 Fit, base trim, after running the tank lower than usual, and clocked 12.7 gallons at the pump. Normally, when filling right when the empty light goes on, I fill around 9.5 gallons. Anybody ever drain their tank this low before and be able to fill past the manufacturer's specified tank capacity? 2 gallons over seems like quite a lot and so I'm suspecting foul play at the meter, but perhaps others have had a similar experience of exceeding the nominal limits of their tank.
Old Feb 25, 2022 | 11:10 PM
GAFIT's Avatar
The fuel station needs to recalibrate their pumps or are intentionally gouging.
Old Feb 26, 2022 | 01:45 PM
MUDKIP's Avatar
If you have something similar to Florida (FDACS), I would call the number and report it.
I did it before when a gas station overcharged me and pumps were clearly tampered with.
Old Feb 27, 2022 | 10:32 AM
NWCH's Avatar
Their pumps are off. Your Fit didn't change overnight. Report it.
Old Feb 27, 2022 | 01:37 PM
Drew21's Avatar
Years ago at a rural Missouri station I put something like 2 gallons more than a full tank into a 1996 Ford Escort. I was cleaning the windows and let it go to the "click" so didn't see the reading until it finished. That would be annoying enough, but the tank was near 1/4 when I stopped so the real error was more like 4-5 gallons.
I went inside to complain and they told me that I must have kept pumping after it stopped. Nope.
Then they told me that I must not know the tank capacity, so I got the manual from the glove box.
Then they told me that the manual must be wrong. I suppose that's possible, but in 5+ years prior to that I had never come close to getting that much gas in the car even when closer to empty.
They then encouraged me to just keep moving down the road. I was by myself, and in a hurry, so I figured that a few bucks (gas was way cheaper at the time) wasn't worth getting into a tussle.
But, it definitely happens so if you have the ability I would definitely report it.
Old Feb 28, 2022 | 11:34 AM
Dduelin's Avatar
This sounds like a reasonable place to start a report: https://www.oregon.gov/dcbs/pages/index.aspx
Old Feb 28, 2022 | 03:10 PM
mobby_6kl's Avatar
Are you sure about the spec? The one I found here says it's 42l / 11.1 gallons: https://www.ultimatespecs.com/car-sp...z-(GD)-14.html
The rest could be in the filler neck or something. Although you'd have to run it really dry.
Old Feb 28, 2022 | 06:26 PM
Brain Champagne's Avatar
Easy enough to check by buying a 5 gallon gas container. Could also bring a scale with you.
Old Mar 1, 2022 | 01:27 PM
AirborneRATT's Avatar
@mobby_6kl 11.1 gal is for the Jazz. The Fit is 10.6 gal. Difference between European vs US models. Good eye though. Having a 2010 myself and driving my Dad's 2013, I am confident in the 10.6 gal fuel tank. The gas station is ripping off customers.
Old Mar 1, 2022 | 06:24 PM
der Mond's Avatar
I top my tank to the top of the filler neck and get an extra two gallons in.
BankWalker
May 5, 2019 09:55 PM
marklj
Dec 22, 2012 02:01 PM
running
Jul 25, 2012 10:11 PM
Wafit
May 2, 2012 03:42 PM
Gordio
May 3, 2008 11:02 PM
