2008 fit sport 5 speed manual issues
Old Apr 16, 2022 | 11:42 PM
Mattyboi67's Avatar
Ok a little back story so I bought a 2008 honda fit with 177k miles on it for 2500 bucks off some car salesmen the car seems to have an aftermarket exhaust and possibly other after market parts definitely has a k&n air filter seems to be lowered as well suspension feels kinda rough and the alignment is a little bit off definitely drives alot faster then I expected it too and my coworker said he had an 07 manual fit and this one is way faster and torquay
So my main issue is after having the car for about a month it's starting to grind gear 1 2 just really feels like it's in and waaaaaank and yesterday I drove for about 2 hours on the high way and toward the end it started popping out of 5th gear now that that's happen it just feels hard to shift into any gear any thoughts ?
I'm figurin I'm probably going to need to rebuild the transmission butt just being hopefully someone on here might be able to point me in the right direction
Old Apr 17, 2022 | 05:44 AM
Mister Coffee's Avatar
You might check the MT fluid and replace it. But if the car is popping out of gear, the problem may be more serious,
Good luck.
Old Apr 18, 2022 | 05:31 AM
mobby_6kl's Avatar
Wow that was really difficult to read without any punctuation
Yeah I doubt any amount of flud change will helpt at this point, seems like it's toast. Rebuilding isn't too difficult (I've done it and I'm a complete idiot) but I doubt it will make any sense since you'll probably have to replace with OEM Honda parts and it will be $$$. IMO getting a junkyard transmission would be better, but YMMV depending on availability and costs wherever you are.
Old Apr 19, 2022 | 08:53 AM
hugojose's Avatar
Don't forget the clutch, which is a wearable item. .......and am wondering. Can you shift when engine is off??
Tluth32
Feb 4, 2015 07:17 PM
Canoehead
Apr 25, 2014 10:20 PM
sean5995
Dec 14, 2012 02:20 PM
dthdabomb89
Apr 27, 2010 04:49 PM
Shockwave199
Jan 12, 2010 11:06 AM
