#4 spark plug keeps backing out
Old Aug 28, 2022 | 10:26 PM
MTLian's Avatar
Hello,
so I checked my plugs as I try to do as much as possible (ok about yearly) and no 4 was loose again and coil pack is all gunked with burnt oil. I’m guessing the threads must be bad in the head. This is not the first time this cylinder’s plug has come loose. What can I do? I thought of using some high temp blue LocTite but it seems that the consensus on the Internet is that my engine will explode if I do that.
I snapped a pic of my coils. They are in the order of the engine. No 1 looks like it was never used and no 2 & 3 are dark blue and 4 is gunked from the loose plug. What gives? I guess it’s the excess heat coming from 4 that darkened 2 and 3 ?
Old Aug 29, 2022 | 07:04 AM
Jimmy101's Avatar
You can use "very small" drop of Red loctite This red stuff melts at 500F.
Old Aug 30, 2022 | 07:15 PM
doctor J's Avatar
They all leaking a bit but #4 is the most.
Have you been using anti seize while installing these plugs?
What brand of plugs?
Did the old plug came out with some effort?
Every Fit I see now on the junk yard has leaking plugs BUT they are TIGHT!
I would suspect a crack between the threaded hole and exhaust port
jy1129
Oct 18, 2020 06:42 PM
MEATBABY
20
Apr 28, 2017 12:50 PM
Sid 6.7
Apr 3, 2017 10:50 PM
noelrobles22@gmail.com
Jan 21, 2016 09:00 AM
jkskrn
Feb 18, 2013 10:26 PM
