Idler Pulley
Old Sep 10, 2022 | 02:32 PM
Peter o's Avatar
Question Idler Pulley
Hi all, I have an 07 Honda Fit. I recently replaced the idler pulley on my car. The engineers over at Honda thought that it would be a great idea to have the idler pulley spin the same way that unscrews the bold holding the pulley to the engine block. Consequently, the pulley keeps unscrewing itself. If I screw it down real tight, the pulley stops spinning all together. Any idea's or experiences?
Old Sep 10, 2022 | 04:54 PM
domoMKIV's Avatar
You probably need to add a washer to space the new pulley so that when you tighten it, it doesnt end up unable to spin. The aftermarket pulleys seem to be different from the OEM in the way they are designed, I had to do the washer trick myself with my Gates pulley. If that idea doesnt sit well with you, you could press out the old bearing from the OEM pulley and press in the new bearing from your new pulley.
For more reference: https://www.fitfreak.net/forums/gene...ml#post1230848
Old Sep 13, 2022 | 10:16 AM
doctor J's Avatar
Thumbs up
Are you using genuine part or aftermarket?
If later, have fun.
https://www.fitfreak.net/forums/1st-...-pictures.html
Old Sep 14, 2022 | 06:00 PM
Jimmy101's Avatar
I changed mine twice never had any problems. Perhaps you could use some loctite on the threads.
Giovanny Alan Alvarado
Apr 27, 2025 01:09 AM
Peter o
Sep 10, 2022 07:03 PM
LeighOriana
May 25, 2022 09:45 AM
running
Apr 5, 2014 12:11 AM
LastDance
Nov 13, 2010 09:14 AM
