Fit 2007 whining noise
Old Oct 4, 2022 | 10:05 PM
georgi6's Avatar
My first post from 9/30 was deleted for some reason.
Honda Fit 2007 made a noise for 10 days and then disappeared.
It comes at idle, no change with revolutions. It seems it is not the serpentine belt.
What could be the reason?
Old Nov 15, 2022 | 06:46 PM
mifesto's Avatar
considering you are idling, it may to be worn pulley bearings.
Old Dec 4, 2022 | 03:19 PM
prizedcoffeecup's Avatar
I just had this issue recently and was searching for another issue on the forums when I came across your video.
You will want to investigate the idler pulley first and foremost in your serpentine belt system. Yours doesn't sound quite as bad as mine was just yet, but I don't think its going to last too much longer...check how much tension there is in the belt too, you should be able to twist the belt no more or less than roughly 90 degrees by hand ideally.
Old Dec 26, 2022 | 11:47 AM
mifesto's Avatar
take a screw driver and while car is idling, touch it to suspect parts and listen to the noise. that can be dangerous so take screw driver and combine it with plastic jug as shown in this video. credit goes to eric O from southmain.
Old Dec 29, 2022 | 10:22 AM
georgi6's Avatar
You guys are correct. - It was the pulley.
The drive belt was also replaced.
RobFit07
Dec 9, 2021 08:53 AM
georgi6
Sep 26, 2018 09:48 AM
dpgmccomas
Sep 26, 2017 08:34 PM
Frank120
Jul 25, 2017 11:08 PM
cab02149
Sep 25, 2011 11:01 PM
