Bypassing A/C compressor on an 08 Fit
Old Jul 13, 2023 | 09:44 AM
Drewmann's Avatar
Smile Bypassing A/C compressor on an 08 Fit
My air conditioning compressor clutch was screaming, and when I finally took it apart to replace the clutch, i found the front of the compressor had broken off inside the clutch housing. So it needs a $200 compressor. Being retired and broke, I searched for a belt for this year Fit with no A/C and found that they all came with A/C in the US. Soooo, I took a piece of thin rope and wrapped it around the pullys and it measured about 35". Napa had a belt that was 35 1/4 and it worked perfectly! I then got a crew cut so I can drive in the summer with the windows down!
2008 Honda Fit alternator belt with no A/C
Napa 25050345
Gates? 5PK880
Old Aug 4, 2025 | 09:31 AM
Thunder1993's Avatar
Help
My 2008 Honda fit, the ac compressor seized up. I need a way to bypass it so I can drive my car again. Are there any bypass pulleys or methods to help?
Old Oct 7, 2025 | 09:54 AM
mifesto's Avatar
im probably too late to help you but i will reply anyways. clutch isnt full time engaged w pulley, so if AC comp is seized up it wont prevent serp belt from spinning if AC comp isnt engaged. when AC comp is engaged, it activates magnetic stator that pulls clutch closed w pulley. long as thats not happening, pulley can spin freely regardless if AC comp is seized or not.
Old Nov 1, 2025 | 10:48 AM
AriQB3's Avatar
You can also unscrew the clutch and leave the pulley there for now. May have to jam something near the pulley so the belt doesn't slip when you're breaking the bolt(s).
Been there- done that. Removed the compressor and hard lines. Swapped a shorter belt in. If it's hot I crack the windows or swap to passthrough vents. I don't know why people need frigid cold air anyways...
Red.velvet.ghost
Sep 3, 2022 04:25 PM
Benzler
Aug 25, 2022 10:30 AM
gadfly
Jul 19, 2022 11:48 AM
iandunham
Dec 1, 2019 05:09 PM
vickieajc
Dec 28, 2014 12:57 PM
