What tool to loosen serpentine belt tensioner?
Old Sep 10, 2025 | 11:45 AM
ShaneMac613's Avatar
I'm getting an odd sound in the top end and trying to narrow it down. I'm hoping it is a bad bearing in the belt system but don't have anything that is thin enough to get the tensioner loosened. What do you recommend?
Old Sep 17, 2025 | 10:36 AM
doctor J's Avatar
just making sure we are talking about 2007 or 2008 year model with manual tensioner?
Old Sep 17, 2025 | 10:54 AM
Yup, I don't have anything that will fit on the alternator bolt to free up the manual tensioner. I think I'll need to a thinner 3/8 ratchet or pick up a pass thru ratchet set.
Old Sep 17, 2025 | 11:39 AM
doctor J's Avatar
I used 12-point 12mm box offset wrench (Westward 12/14) only 1 turn is needed to unlock the tensioner
Old Sep 17, 2025 | 11:42 AM
I didn't even think of an offset wrench, that is a great solution. Thank you.
Old Oct 7, 2025 | 09:44 AM
mifesto's Avatar
"odd sound" is probably your idler pulley, the bearing is common failure point.
Old Nov 1, 2025 | 10:52 AM
AriQB3's Avatar
Get a screwdriver or long extension. Put it near where you think the sound is and put the other end of the extension on the bone in front of your ear. Diddo on the idler pulley. I got rid of all my AC stuff because I didn't trust the aftermarket pulley designs.
grommet
Apr 27, 2026 09:57 PM
Mister Coffee
Jul 25, 2025 05:48 PM
lightyear22
Oct 1, 2014 07:47 AM
hazzard
Nov 20, 2013 01:38 AM
