Anyone Foung Spare Tires?
Old Nov 21, 2023 | 01:27 PM
aviategw's Avatar
I picked up a used '07 Fit last week. It will be a daily driver for me, used mostly on a 500 mile commute once a week.
The spare tire that came with it had obviously been quite used. In doing a little research, I can't find a replacement new spare tire for sale anywhere. I don't really want a used/pre-owned spare tire from a junkyard as they are all likely 17-18 years old now.
Any suggestions for a place to buy a new spare tire?
Thanks!
Old Nov 21, 2023 | 01:58 PM
Steve-o's Avatar
Pretty much any place that specializes in selling tires. The Honda dealer should be able to sell you one, so can Discount Tire (online or brick and mortar) and other tire stores. Dealer probably is the most expensive of the lot.
Old Nov 21, 2023 | 02:55 PM
Drew21's Avatar
Your spare tire should show the size on the sidewall. With that information pretty much any tire shop can order a new spare for you, or you can do it yourself online.
According to this (https://sparetire.com/Honda/Fit/), the spare tire size for a 2007 is 125/70R16. There aren't a lot of options (obviously), but Tirerack.com, Walmart.com, Discounttire.com, and likely many more all carry a Continental brand spare tire in this size.
As an aside, I've always wanted to mount four spare tires on a car and have a modern-day Model T experience. Probably not safe on the highway, but it would be a good way to taunt all the stanced cars on the street.
Old Dec 1, 2023 | 04:31 PM
aviategw's Avatar
The spare size is T125/70D14. I cant find this size anywhere online; it is a highly unusual size that seems to have only been used on the Fit. I even tried the dealership, no luck.
I’m at the point of trying to find a different size that might fit the spare wheel/rim thats in the car.
Old Dec 1, 2023 | 06:04 PM
Drew21's Avatar
I agree that there don't seem to be any 125/70R14 tires available, which makes me ask if you are sure that your spare is a 14-inch rim?
A 125/70R14 spare would be tiny, whereas the tire I suggested (based on the Googles) is basically the same diameter/circumference as the stock tire sizes for a 2007 Honda Fit.
175/65R14 = 23 inch diameter
195/55R15 = 23.4 inch diameter
205/45R16 = 23.3 inch diameter
125/70R16 = 22.9 inch diameter
125/70R14 = 20.9 inch diameter
One of those is not like the others, and wouldn't play nicely as a spare tire.
Old Dec 2, 2023 | 05:57 AM
aviategw's Avatar
Old Dec 2, 2023 | 09:48 AM
Drew21's Avatar
Well, I guess you learn something new each day. In this case, I have learned that the Internet can lie to me. My world is shaken. Give me a moment...
Here is the same 125/70R14 tire you have located at a shop in PA.
https://www.henisetire.com/tires/vie...mpa-125-70r14/
Here's a 115/70R14 tire. Just a bit smaller than one you have, but maybe replacing a tiny tire with a tinier tire could be acceptable to you.
https://shop.maxxis.com/products/com...40406598713479
A better bet might be to look for a junkyard spare tire rim from a GE8 Fit, on which you could put a new 125/70R16 (diameter 22.9 in) or 135/70R16 (diameter 23.4 in) tire which seem to be more readily available. My 2010 Fit Sport has the latter.
Old Dec 27, 2023 | 01:25 PM
fit2bking's Avatar
You can get this tire from honda, but don't ask for it for our fits. You have to say it's for the last generation fit, it has a different part number but it
is the exact same size!
cavernap
Dec 13, 2019 01:13 AM
Corvin
Jul 14, 2015 07:25 PM
NEK FIT
Jun 30, 2008 07:52 AM
plastidip
Sep 12, 2007 05:45 PM
Martee
May 14, 2006 06:26 PM
