Oil
Old Dec 5, 2023 | 03:26 PM
AGoines's Avatar
Oil
Is this way too much oil? Busted the oil pan, had it replaced and when we got it back it’s this far over the fill line
Old Dec 5, 2023 | 06:20 PM
Drew21's Avatar
My recollection is that there is 1 quart between the dots, but you should confirm that. If I'm correct, you have around 1 quart too much, which is a significant amount in an engine that calls for a bit under 4 quarts.
If you're asking what you should do, I would try to get closer to the correct amount. If you have the right size tubing you can suck oil up the dipstick. Alternatively, you can loosen the drain plug partially and let some drip out, tighten the plug, check the dipstick, and repeat as necessary. A better approach would be to drain into a container you have marked for 1 quart. If you're careful (e.g., clean around the drain plug before letting your nice clean oil run all over it, drain into a clean container, etc., you should be able to reuse drained oil if you go too far.
Old Dec 6, 2023 | 09:37 AM
Silver GD3's Avatar
It's 3.8 quarts with new oil filter. Just drain it down to the top hole of the dipstick.
guywire
Jan 3, 2024 12:36 PM
Jcasenave92
Nov 8, 2020 01:58 PM
Eugene.Atget
Dec 11, 2010 07:21 PM
Margelous
Jul 20, 2010 11:42 AM
Daemione
Apr 9, 2009 11:47 AM
