No crank
Old Jul 9, 2024 | 02:34 AM
dadinmt's Avatar
No crank
After replacing the steering control module this 08 fails to crank. Battery is new and fully charged, everything else works.
All the connectors went back ok, the replacement part has the same numbers.
Any suggestions?
Old Jul 9, 2024 | 10:41 PM
dadinmt's Avatar
Additionally the code reader does not connect whereas it did before. All fuses test ok. Is there a relay or something I'm missing?
It's a difficult switch involving pulling on the fuse board but as much as I can see nothing has been dislodged.
Old Jul 10, 2024 | 06:34 PM
sae.fit's Avatar
I picked up my 2007 Honda Fit and a week later my vehicle would not crank. It turned out to be a bad fuel pump so I replaced that and my car is back up and running. Turn your key on to ignition on and see if you hear any sound from your fuel pump area.
Old Jul 10, 2024 | 09:22 PM
dadinmt's Avatar
Fuel pump runs, does not crank. Everything worked fine before exchanging the EPS module except for the intermittent steering.
Puzzling why the reader can't connect.
Old Jul 11, 2024 | 02:44 AM
dadinmt's Avatar
Code reader works after a battery dis and reconnect, shows no codes.
Ignition switch lites up the black starter wire but starter does not spin.
Jump black wire at starter and the engine cranks.
Where does the starter wire go from the ig switch before it goes to the starter?
I assume there is a safety switch somewhere.
Old Jul 11, 2024 | 10:06 PM
dadinmt's Avatar
Anyone know why there seems to be no factory service manual for the 08 Fit?
I find 07 and 09+.
Old Jul 12, 2024 | 12:32 AM
dadinmt's Avatar
Further progress
I can start the engine by jumping the black wire to the solenoid with the key on.
Engine running, everything works as it should, electronic steering included.
So the only problem is the start circuit that I can bypass.
As a last resort I will tie into the start wiring at the switch and run a wire direct to the starter.
But I would love to figure this out.
Old Jul 12, 2024 | 12:11 PM
sae.fit's Avatar
Hmm, I wish i were more mechanically inclined to be able to assist you. It sounds like something to do with your electrical? Keep us updated on what you were able to solve.
Old Jul 22, 2024 | 09:12 AM
dadinmt's Avatar
Fixed - But
I solved it by splicing a wire into the start wire at the ignition switch and running it across to the passenger side connector that has the wire coming from the starter, Could not disconnect that wire so clipped it and connected it to the wire spliced to the start switch. It starts, everything works, but it's still a mystery.
ArnoldsFit
Dec 14, 2019 11:38 AM
kyleighnichols
May 8, 2017 01:24 PM
Marin Guillen
Aug 4, 2015 04:48 PM
vidvicious
Jun 11, 2015 09:32 AM
AnlDyxp_GD3
Dec 4, 2010 08:58 PM
