Should I Change 2007 Fit Transmission Fluid?
I recently bought a 2007 Honda fit with the 5 speed automatic transmission. It has 167k miles and I’m not sure if it has ever had the transmission fluid replaced. Would it be bad to change the fluid now?
you sure it is MTF oil?
unless you are having transmission problems, especially new ones. then don't delay on the work. my two cents.
....He said is a manual tranny, not automatic....., and because it does not have a troque converter (fluid coupler), it is not really a fuid, but oil, Honda MTF, or even 10W30 or 10W40 could be used in a pinch. .. . Since the oil only lubricates, it does not perform a "turbine duty' (does not transmit power), it does not need to be changed often like a ATF,.......
.......Still, it does not hurt changing it after 60,000 miles
nickjaco19@gmail.com
Mar 17, 2022 10:03 PM
JerryHughes
Jul 13, 2019 11:09 AM
