Po335-po339
Old Jan 24, 2025 | 06:52 PM
roycampbell's Avatar
Po335-po339
my 08 has a 2 codes po335 and po339 replaced crankshaft position sensor no change, cleared codes and lite came right back on immedietly,2 weeks ago number 1 cylander spark plug blew out of the head replaced with new and new coil,the plug screwed in just like normal and i tried to remove the other three but couldnt loosen them so i just left them alone,what is up with this fit,its having a FIT thanks.
Old Jan 30, 2025 | 03:10 AM
2015LXFIT's Avatar
Advise for crank patter relearn. I have a GK5 and can confirm my vehicle has this option- not shre about the GDs.
If you got a cheap sensor, advise for warranty for faulty part.
If that doesn't work, advise to check continuity to PCM and outputs.
Could also be out of time.
Good luck.
jd789
Jan 26, 2024 03:18 PM
Triskelion
Sep 23, 2022 02:58 AM
NewEnglandD
Jul 16, 2021 02:37 AM
benmaggoswd1
Feb 27, 2018 05:17 PM
gd3vbp
Apr 21, 2009 01:48 PM
