Request noise diagnosis from Fit experts
Old Sep 12, 2025 | 12:55 PM
chucklesmcfarland's Avatar
Question EDIT - Updated with youtube video - Request noise diagnosis from Fit experts
EDIT - updated with youtube video
Hi all,
Our family has a great little first gen fit that has had a noise over the last year or so that I am having trouble pinpointing. One mechanic has diagnosed sway bar links, but after taking a look myself under the car I can't replicate either the noise or see any play in the suspension. Only noises I did find were in the axle which did have a bit of side to side play but this was dismissed as 'normal'. It really does seem to come from a more central location and seems like it could be a mount or who knows. I am attaching a video in hopes one of the experts here can point me in the right direction.
Thanks all.
Last edited by chucklesmcfarland; Sep 15, 2025 at 02:49 PM. Reason: updated with youtube video
Old Sep 12, 2025 | 07:59 PM
Sway bar end links are a very common cause of front end noises on these cars. I’d recommend uploading the video to youtube, may get more clicks than a file
Old Sep 15, 2025 | 02:49 PM
Good idea Mike, thanks!
Old Sep 16, 2025 | 02:33 PM
frog03's Avatar
Hard to make the end links make noise while underneath the car.. you don't have the weight of the car bouncing up and down.
I had a ram with bad sway bar bushing. No visible problems and no noise while under it. Made the same noise as in your video. To be clear, it was the bushings. Not end links.
Old Sep 17, 2025 | 10:32 AM
doctor J's Avatar
First make sure there are no loose interior trim panels, shields and so on
Open the door, grab it and shake the car sideways by moving it up and down. Clunking noise indicate bad sway bar link.
Next check the struts/rear shocks mounts.(big gap , loose feel)
Next get car on the front stands and shake wheels to rule out drive shafts and spun front bearing issues.
Old Oct 7, 2025 | 10:00 AM
mifesto's Avatar
check all engine mounts rubbers, check swaybar endlinks and also swaybar bushings too.
Old Oct 30, 2025 | 01:29 PM
Tripledipper86's Avatar
I’m at a loss my 07 is having a similar sound mostly prevalent when going over bumps. I have replaced sway links, lower control arms, inner and outer tie rods, and strut assemblies. Still has noise but as far as I can tell not much play in the wheels or the typical CV axle click while turning.
Kxbronco
Aug 31, 2023 10:30 PM
Joey217
Sep 20, 2022 03:25 PM
jy1129
Jul 31, 2020 02:23 AM
tekito
May 3, 2010 06:36 PM
bestfit
Feb 2, 2007 10:20 AM
