Subs, Amp... Head Unit
Old Sep 22, 2008 | 11:22 AM
ShannonHonda.aka.Fit's Avatar
Thumbs up Subs, Amp... Head Unit
Okay I did my honda fit. Well not literally. I connected a 10" Sub and an amp to my factory head unit.
What you need-
Amp wiring kit
Line Converter
Soldering Gun
Electrical Tape
Phillips #2
8mm
10mm
1) Was pretty simple once I stopped and thought about a plan. I put my power (4 gauge wire) in through the passenger side of the fire wall. I pulled the sides of the interior out and ran it along to the back.
2) I connect my ground to my back clip in my hatch.
3) I undid the screw at the bottom of the head unit.
4) Used an 8mm for the two major bolts holding my head unit in. They are deep inside.
5) The dash was then held in by clips, be aware they do pop and ping... dont worry.
6) Connected to the stereo is a large wire harness. Look for the pink and blue/yellow. Those are your +/-.
7) I suggest you use a soldering gun and do it properly. It will avoid anything coming undone.
8) I followed the instructions on the line converter as far as the +/- cause they all have different color wires.
9) Run the RCA from the line converter along the same line of your power.
10) Connect them to the amp.
11) Now you need your amp on a remote/ignition switch. - Now my remote wire is running to the cigarette fuse and is tucked in. This way it turns off when car is off and turns on when car is on.
I soldered it to the NON black wire- Sadly i cant remember the color of the wire i cut. Only two are there so pick the non black one. It should be yellow and green or something...
Anyways if you have any questions you can email me...
Take care and hope this helps!
Old Sep 22, 2008 | 01:01 PM
drock305's Avatar
if you cant find the wire for the remote or if there isnt one on the factory harness or something you can always just run it to a rocker switch or something.. that way you can turn the bass on and off.
Old Sep 22, 2008 | 11:08 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah dude bass knobs are the shit
Old Sep 22, 2008 | 11:37 PM
CorrodesTheFilm's Avatar
So the important thing here is...
How does she sound?
Old Sep 23, 2008 | 08:30 AM
I ended up doing my remote wire for the amp to my cigarette lighter. Cant remember what color the wire was i just know it was NOT the black one.
Yes it sounds awesome.
Old Sep 29, 2008 | 07:10 PM
WSRPRED's Avatar
mmmmmm 10'' sub in fit.... *day dream sequence fading in*
put the back seats down... my girl, a blanket, the beach parking lot...
peaches and cream playing. bass pounding through the sub under us.
F' that! How about some Metal Militia blasting while i'm hittin 1** on the freeway, flying by more rice than you can find in an azain supermarket
okay thats just what im thinkin, i dunno about you all...
Old Oct 8, 2008 | 08:51 PM
Fla3fi's Avatar
I actually replaced the head unit didn't like the sound out of the HU went with Alpine 9884 HU
Got a Profile A600 Amp Bridged to 300 Watts pushing a 10 inch infinity 1050W in a sealed enclosure
and a profile A400 Pushing Infinity 6020CS series 6.5 components
DYNAMATTED OUT and the rear plastic on the side I put bed matting in there
Needless to say its tuned well and bumps hard
Just a thought
Old Nov 29, 2008 | 04:31 PM
having a fit's Avatar
dude i have two 15 inch alpine type r subwoofers two 10 inch mid range drivers one 12 inch mid range driver and two 3 inch tweeters along with changing the headunit and interior speakers 150db's 5500watts in amps my fit rocks hard
Old Nov 29, 2008 | 04:35 PM
pics PLEASEE!!!!!!!
Old Nov 29, 2008 | 05:46 PM
Last edited by having a fit; Nov 29, 2008 at 05:47 PM. Reason: i have the 15's in the actual trunk behind the seats
Old Nov 29, 2008 | 06:42 PM
ahh that's the shit!!!
do you have any more?
i bet this hits so hard!
Old Nov 29, 2008 | 06:55 PM
i have to take more its underconstruction again im lookin to add like 6-8 more speakers and eliminating the backseats
Old Nov 29, 2008 | 06:57 PM
alright cool
Old Nov 29, 2008 | 07:04 PM
kamakurakid's Avatar
Geez, I would love to hear how it sounds. For a minute there I thought it was PhotoShopped. I cannot keep a dime on the dash of the Fit in this city, asking for a crack head to do some window art. You must have a Mother of a dog in the back area....
Old Nov 29, 2008 | 07:06 PM
its ok i need more i do competitions around me when they see my car they say theres that lil car again
Old Jan 2, 2009 | 03:07 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
Old Jan 2, 2009 | 03:14 PM
Hondasforlife's Avatar
you thought about it though i know you did
Old Jan 2, 2009 | 03:16 PM
it sounds pretty good kinda loud with a lot of bass...lets just say you dont need dj equipment if this guy shows up with his car
Silversun82
May 11, 2013 03:41 PM
jeffdawgfan
Feb 16, 2011 09:46 PM
DENRACING
Jan 12, 2010 06:05 PM
Redheart
Jul 1, 2007 02:41 PM
BlueFity2
Nov 28, 2006 01:16 PM
