help with eletrical problem gd3
Old Dec 11, 2008 | 11:21 AM
FELIXY69's Avatar
after cutting the wires to my led strip in the trunk, where it was connected to the trunk's dom light........
my dom light, trunk light, radio, and alarm doesn't work.
all fues are good.
what should i check next.
someone said the BCM could be fried ? where is the bcm ?
thanks
Old Dec 11, 2008 | 11:39 AM
cojaro's Avatar
Did you check both fuse locations? [under the hood and inside the dash]
Old Dec 11, 2008 | 11:45 AM
gimme's Avatar
Master FitFreaker
did you cut the wires at the same time? coulda shorted something IF you cut them at the same time.
Old Dec 11, 2008 | 11:52 AM
koolkevin1107's Avatar
all fues are good.
thanks
the BCM fuse is found underneath the engine bay next to the battery in the triangle shaped fuse box. I'm sure that you burnt it when u cut the wires. It should be a mini ATX fuse, not one of the bigger ones.
Old Dec 11, 2008 | 11:58 AM
FELIXY69's Avatar
YES I CUT BOTH WIRES TOGETHER !!! ......mistakes !!
i always thought the dome lights and radio even the alarm is in differen't wireing loops, in differen't curcits
why they burn together???
Old Dec 11, 2008 | 11:59 AM
FELIXY69's Avatar
and also heard the BCM fuse is $700 cnd ????
Old Dec 11, 2008 | 08:45 PM
Kishore's Avatar
Cargo Area Light, Ceiling Light and Audio Unit all get power from FS8 10Amps fuse which is in the under-hood fuserelay box.
Check this fuse. It will blow if you have cut both the wires together.
I have the wiring diagram in front of me and there is not other fuse in this circuit
Old Dec 11, 2008 | 09:02 PM
Kishore's Avatar
Oops,
There is also FS1 80Amps in the Under-hood Fuserelay box and main fuse also 80Amps in the same circuit.
definitley 10Amps fuse will blow before 80Amps. If any of the 80Amps fuse is blown the vehicle will be dead. Which is not in your case.
Old Dec 12, 2008 | 01:16 AM
accordguyintake's Avatar
you cut both wires together?? ai yi yi....
today in Auto class this guy was taking off a battery terminal.. the positive one and his wrench hit the body panel... i was RIGHT NEXT TO THAT SHIT... omg
He was traumatized after that so i had to tighten the bolts FOR HIM... i screamed and he turned all red cuz he jumped back and everyone laughed at him.. hahah i feel bad But it's all good cuz i made him ghetto-rig the starter so his partner can do the compression test on the car we were working on, 76' Dodge Dart. Nasty condition but DROOL for potential sexy car.
So anyways the moral here is be fcking careful when you're dealing with electricity :]
Old Dec 13, 2008 | 02:43 PM
FELIXY69's Avatar
Originally Posted by Kishore
Oops,
thank you for ur help !!i will check right now !!
Old Dec 17, 2008 | 07:11 AM
FELIXY69's Avatar
so it turns out it was the 10AMP fuse that blew after all..thanks so much Kishore for all ur help !!
Old Jan 2, 2009 | 01:49 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
whenever ANYTHING electrical stops working.....CHECKING THE FUSES IS ONE OF THE FIRST THINGS TO DO (after checking that it's turned on, then checking if it's plugged in)!!!!!
Old Oct 7, 2022 | 12:48 PM
jacubby's Avatar
Bringing this back up from the dead but...
I just bought an 08, same problems, no dome light, radio has no power, door locks only function when ignition is on... Fuse #8 (backup) in the engine compartment is good (I changed it out with a new one just to make sure), all the other fuses look good.
Any ideas of what the problem could be?
Thanks.
lilizm319
Apr 11, 2015 07:08 PM
samson2112
Oct 22, 2010 07:59 PM
setter11
Jun 12, 2010 02:38 PM
Packy
May 16, 2009 09:34 PM
Ritzbury
Oct 17, 2007 01:26 PM
