Wheel width question
Old Dec 23, 2008 | 09:47 PM
HB1320's Avatar
I planning on going 15x8 on the rear but i wanna see it first before I do it anyone has pictures of 8 inchs on the rear of their FiT? i'll really appreciate it.
Old Dec 23, 2008 | 10:45 PM
Fit_Dr's Avatar
Hmmm...8", you better go with a pretty good offset, min 44 probably.
Old Dec 24, 2008 | 04:57 AM
Fit4Trav's Avatar
Nah that's to high of an offset. You coulod go @ least +35 easy and be semi flush with the fender.
Old Dec 24, 2008 | 01:36 PM
adam s's Avatar
i've heard you can't even run 8" wide wheels without doing fender mods.........
idk for sure tho, i wanted some sportmax 501's 15x8 with a 0 offest
Old Dec 25, 2008 | 03:26 AM
Fit4Trav's Avatar
^^The 0 offset will need some fender work if you're lowered
Old Dec 25, 2008 | 03:37 AM
redrumm's Avatar
15x8 with 15 offset looks hard enough
Old Dec 27, 2008 | 03:53 AM
VBP08GD3's Avatar
so 15x8 and 195 tires will rub?
Old Dec 27, 2008 | 03:58 AM
kylerwho's Avatar
spoon fed
15x8 wheel with a 195 is stretching the tire kinda far right?
Old Dec 27, 2008 | 04:07 PM
Fit4Trav's Avatar
Its a mild stretch, not bad @ all
Old Dec 27, 2008 | 07:32 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
don't do it
find another rim
Old Dec 27, 2008 | 07:38 PM
solbrothers's Avatar
werd.
my brother had 205 50 15's on the front of his crown vic. 295 50 15's on the back. same rim size front and back. 15x7
Old Dec 28, 2008 | 01:00 AM
VBP08GD3's Avatar
yo fit4trav what are you riding on?
Old Dec 28, 2008 | 02:05 AM
Arisenfury's Avatar
A 195mm tire is about 7.67 inches. So you'll have about a 1/6th of an inch worth of stretch on either side.
Old Dec 28, 2008 | 04:43 AM
Fit4Trav's Avatar
195/45
15x7
Old Dec 28, 2008 | 11:37 AM
VBP08GD3's Avatar
b/c in your avatar your rims look pretty far out.. you get that with a 15x7?
Old Dec 28, 2008 | 12:23 PM
Fit4Trav's Avatar
195/45
15x7
oopps
+13 offset
They really dont stick out that much maybe a few mm
Old Dec 28, 2008 | 12:25 PM
iheartJDM's Avatar
nope i would hardly call it a stretch
my friend is running 15x8 +25 with 195/50's it hardly has a stretch to it
Old Dec 28, 2008 | 04:19 PM
SFactor2's Avatar
oopps
+13 offset
they must eat your fenders during hard cornering (unless your just a cruiser)
Old Dec 28, 2008 | 04:21 PM
SFactor2's Avatar
werd.
when i go camping i don't shower for days, not too bad of a stretch but FAR FROM IDEAL
Old Dec 28, 2008 | 04:35 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
With a 44mm offset and an 8in wide wheel pretty sure itll rub on the strut and rear inner fenders.
A 15x8in wheel needs at the HIGHEST a 30 or 35mm offset.
And thats hard to find in an 8in wide wheel.
Because he needs a 195/45.
