*h-fit intake* broken!!!!
Old Jan 16, 2009 | 12:36 PM
der Mond's Avatar
Just an add-on thought - Some guys have installed it without removing the battery, and the fit can be off a bit. If you remove the battery and make sure you snug the rubber sleeve on to the manifold and intake, then install the battery snugged over to the right as far as you can skoosh it, it will not rub. In that case the intake can still oscillate with engine vibration due to the flex of the rubber sleeve, maybe that's the problem.
Old Jan 16, 2009 | 04:03 PM
Shaggs2Dope's Avatar
Frequent FitFreak Poster
still seems like it should be made od sheetmetal/aluminum with a ceramic coating
Old Jan 21, 2009 | 11:44 AM
VBP08GD3's Avatar
the heat is probably cracking plus the stress on the battery... you guys can try a relocator
EXCellR8
Apr 6, 2014 06:53 PM
Socialvegetable
Oct 6, 2009 10:17 AM
petwhookie
16
Feb 4, 2009 11:29 PM
PR fit
May 30, 2008 03:00 PM
samwell
Jun 18, 2007 11:13 PM
