Getting a clunk noise in front end
Old Feb 18, 2009 | 03:01 PM
VBP08GD3's Avatar
Exclamation Getting a clunk noise in front end
I have put springs on recently and yesterday i started getting a clunk noise in the front end of my GD3 as if something is loose. and i can fell it hit with the brake is at. it usually comes when there is hard steer or when i go over a bump. anyone know what the hell it is? Its an 08 Fit i have not even made a year with the car yet til May.
Old Feb 18, 2009 | 03:08 PM
sl0wp0k3's Avatar
tighten your sway bar end links... if that doesn't work recheck all your work make sure everything is tight.
Old Feb 18, 2009 | 03:26 PM
Tofuman's Avatar
^what he said. you can get a clanging sound if your end links are loose. also check to make sure you've tightned all of the bolts down.
Old Feb 18, 2009 | 03:33 PM
VBP08GD3's Avatar
k will do i been searching online.. and a lot of people are saying to change the sway bar bushings... but do you really think they will wear out that fast i just got the car in may 08 and its a daily.
Old Feb 18, 2009 | 03:39 PM
willitfit's Avatar
either endlinks or you didnt tighten the top all the way.
Old Feb 18, 2009 | 03:45 PM
Fit4Trav's Avatar
^^Tighten the top all the way.
Old Feb 18, 2009 | 03:49 PM
VBP08GD3's Avatar
the top meaning where the suspension mounts on under the hood
Old Feb 18, 2009 | 03:51 PM
Fit4Trav's Avatar
Yeah the top of the strut. I think there is a bolt there...I dont remember. My xB made that noise after I installed my springs, its cause i didn't tighten the top nut all the way down
Old Feb 18, 2009 | 03:58 PM
willitfit's Avatar
yeah after you install the springs you tighten the top as much as you can then you put on your wheels and lower it and it should travel up some more and thats when you tighten it all the way down as much as you can. if you didnt do that then thats most likely the noise
Old Feb 18, 2009 | 04:07 PM
VBP08GD3's Avatar
damn, towelie and i tightened that shit as hard as we could... well mess around with it again to see.. i been riding around with my springs for 2 weeks and now this shit just happened yesterday
Old Feb 18, 2009 | 04:24 PM
Fit4Trav's Avatar
It may have just come loose. Did you use an impact gun?
Old Feb 18, 2009 | 04:27 PM
VBP08GD3's Avatar
naw bro.. just hex and ratchet
Old Feb 18, 2009 | 05:54 PM
koolkevin1107's Avatar
Hmm... did u make sure to cut ur bump stops? Maybe u forgot to cut em.
Old Feb 18, 2009 | 06:12 PM
mahout's Avatar
Since you just installed new (probably lowering) springs check for free play in the springs in the shock seats. That usually arises when the installation didn't have the ends of the springs seated against the spring stop when the spring was released from the spring compressor. That akllows the spring to rotate as it compresses and rebounds and the spring hits the stop.
Another possibility is the antisway bar as it is somewhat loosely bound and it can rap against the frame as it winds and unwinds. thats possible regardless of new springs.
Otherwise check all nuts and bolts for proper tightness.
And check for interference between any of the suspension members and the shocks or linkages.
Old Feb 18, 2009 | 06:24 PM
rvall004's Avatar
i was having the same tproblemn with the coils..whta i did was take the whole thing apart and put it back together..in an organize manner...then the noise was gonna for good
Old Feb 19, 2009 | 12:53 AM
VBP08GD3's Avatar
yea we cut the bump stops
Old Feb 19, 2009 | 12:54 AM
VBP08GD3's Avatar
im gonna try all this out with eriel today hopefully
Old Feb 20, 2009 | 12:27 PM
VBP08GD3's Avatar
it was the tie bar... it was upside down... so we lined it up and made sure it was straight.. and the noise is gone...
Old Feb 20, 2009 | 12:28 PM
VBP08GD3's Avatar
thanks for all your help guys...
Old May 14, 2022 | 07:55 PM
Fitnjammin's Avatar
Irregular clunk. 2010 stick shift
I get an irregular clunk mostly on bumpy roads. I put the car on my friend’s lift. After pushing/pulling on various steering/suspension components he pushed up up on the passenger side tie Rod and the noise came from where the tie rod goes into the steering rack which is consistent with where the noise sounded like when I was driving it. More to come!
kinosh
Apr 15, 2019 10:11 AM
chrisw_lfp
Aug 7, 2017 04:41 PM
daygobaker
Jul 15, 2017 02:25 PM
DrKelso
Aug 30, 2012 07:19 PM
JVH
Jul 19, 2011 08:22 PM
