I want black headlights/fog light housings
Old Apr 3, 2009 | 01:39 PM
Ciggy's Avatar
What kinda of paint do I use for these two pieces and what type of preparation is needed? Do I need to strip the factory paint off paint and clear coat the housings? I have never painted anything and I don't want to make anything look bad.
Would it be expensive to have a body shop do?
Old Apr 3, 2009 | 04:14 PM
Rubba Burna's Avatar
HID Addict
i could be wrong, but i heard you can do it in your oven... or maybe thats something else....
Old Apr 3, 2009 | 04:30 PM
Ciggy's Avatar
taking the word baking to a literal term.
Honestly it might be possible but i am not sure I want to do that. I'm going to go get a quote at the body shop that replaced my bumpers.
Old Apr 3, 2009 | 05:03 PM
andyd's Avatar
Its very simple.
Just get some flat black trim paint. Thats what i used, worked great.
As for the oven...you just put the lights in the oven to make the sealant around the headlight soft so you can pull it apart.
There is a DIY thread on it.
Also the head lights are easy, get some fine grit sand paper, sand them down good, paint away.
Old Apr 3, 2009 | 05:07 PM
Fat Ping Cat's Avatar
well first of all... search the fourms, a lot of people have done this
You risk damaging your headlight housings if you bake them and don't do it properly but i believe there is a thread from a while back from someone who did the projector HID mod. they did a good diy write up with how to go about cracking them open.
you could also just buy a new set of headlights (what I did because I don't have much time to screw with that crap) but its kinda expensive
as for the foglights you need to take some sand paper and scuff them up pretty good (use a very fine grit) then spray some adhesion promoter and then paint them black. i used a product from duplicolor called "bumper coating" spray that on by itself and it dries to a silky smooth flat black. koolkevin did a write up on refinishing some plastic interior pieces which i used as a guide
Old Apr 3, 2009 | 05:16 PM
andyd's Avatar
cali_fitted
Feb 23, 2009 09:22 AM
QuickGD3
May 19, 2008 02:33 PM
caie-u
Mar 20, 2008 08:36 PM
andyd
Feb 11, 2008 10:40 AM
runbikerun
Jan 14, 2008 02:24 PM
