Independent Fog lights fried my harness?
Old Jul 20, 2009 | 03:44 AM
willitfit's Avatar
hmm sucks!
if your local to a junkyard i say if they cant order you a new one, go check out the junkyards to see if they have fits.
Old Jul 20, 2009 | 07:01 AM
Rubba Burna's Avatar
HID Addict
hmm sucks!
<:O fits in the junkyard!?!?! thats sad to hear
Originally Posted by Arisenfury
Well they work with the headlights still, I never had them wired up to stay on with the brights... I have big hands and there isn't a lot of room down there for that so I never bothered. How sensitive of a fuse do you think? Something like a 10 amp?
yep i used 10 amps on mine.
Old Jul 29, 2009 | 06:17 PM
Necos07's Avatar
Try a 5 or a 7.5 amp fuse so it pops right away if anything happends just to give you piece of mind. But most folks are using a 10.
Originally Posted by secondspassed
So if i grounded my Fog light relay to have them stay on with the brights, but didn't do the *full* independent fog light mod, am I safe from this issue?
I think you might be in worst danger because your pushing alot more power using high beams & fog lights compared to just independant fog lights. Just my .2 cents
Old Jul 29, 2009 | 07:07 PM
TheImmortal's Avatar
The red/yellow wire was cut and plugged directly into the fuse. I did not use an inline fuse.
well..... now u know what the purpose of a fuse is
Old Jul 29, 2009 | 07:22 PM
Yeah we already covered it that it wasn't under warranty. The only time it was in question was before they knew exactly what caused it. I had no problem paying and owning up to my mistake. Just letting other people know about it before it happens to them.
it is NOT exactly known what caused the problem
which method of "independent" fog lights did u use?
can u have fogs and high beams on at the same time WITH NO KEY in the ignition?
where on the harness did the heat originate (there r a lot of other systems on that harness besides the lights)?
did u use solder?
the real problem is is that even if the fog light mod was NOT the source of the problem, the dealer will deny any and all responsibility on their part to avoid any warranty work since u did modify the wiring
for about 30min of work u could of bypassed whatever was melted by using solder, some kind of connector, or just twisting the wires together.......oh well
Old Jul 29, 2009 | 08:34 PM
Arisenfury's Avatar
I followed the directions as they were in the thread here. Albeit I was following the original thread as it was being worked out before people even had wiring schematics. The fogs only came on when the key was in the ignition and still turned off with the high beams. The only thing I can think of is that the way people are wiring them up is instead of the harness getting a current when the headlight switch is turned on, we trick it into thinking the headlights are on and give it a constant power source instead of one that only turns on when the headlights are and perhaps the current from the relay is less than just a constant from the fuse box.
It's funny how upset people get at me for this even though I haven't bitched once about having to pay for the mistake. I'm just trying to let others know it is possible to do if not done correctly and perhaps even if you've done it correctly. It took 2 years to show up my way it very well could show up with more time on methods done with an in-line fuse.
Old Jul 30, 2009 | 08:25 AM
mahout's Avatar
The best way is wiring directly off the battery and independent of the vehicle wiring. Use sufficient wire, such as 8 or 12 gage, fused and switched on the power side (+) and make sure you are not hindering the satellite wiring requirements.
Thinking your using 150 watts on each, that needs a quick blow 15A fuse if they are in parallel on each leg and 30A if they are in series. Ditto the switch which should have 30A capacity.
Old Jul 30, 2009 | 08:52 AM
Arisenfury's Avatar
Thanks for the heads up, I was considering wiring them up that way but I think I'm just gonna leave them alone. I missed them for a week but now it's not that bad.
Old Jul 30, 2009 | 01:13 PM
B1str0's Avatar
RubberBabyBuggyBumpers
Originally Posted by Rubba Burna
the only problems i encountered was my fog light bulbs blowing up, the glass expanded and bulged. scary stuff. i assumed that was from using the high beams with the fogs. i still use em together, but on a very minimum. im hoping wit wont have the same affect with real HIDs :S
the problem was the cheapo fake Xenon style bulbs... seen it many times before no worrys about the hid's they're safer
Old Mar 16, 2010 | 09:16 AM
asiann1nja's Avatar
man, i am about to do the independent fogs and i hope this doesn't happen to me.
Old Mar 16, 2010 | 11:42 AM
Ciggy's Avatar
Makes me feel better knowing I have a add-a-fuse in there of course it could still happen to me.
Old Mar 19, 2010 | 09:46 PM
  #32
1904-08-fit-sport's Avatar
Well I just did the indie fogs 15mins ago. So fingers crossed That I don't have tha same prob but I did use the add-a-circuit.
tyler968
Sep 29, 2018 01:27 AM
GinoLicious
May 9, 2014 11:41 PM
jeff bayne
May 2, 2013 09:04 PM
Raouf
May 2, 2010 09:10 PM
E = Mc2
May 14, 2009 04:14 AM
