my fogs arent working :/
Old May 2, 2010 | 07:52 PM
Raouf's Avatar
well the title says it all...
i parked and looked at the reflection in the store window and saw that my fogs weren't on, i always have them on when my lights are on so i tried to turn them on and nothing... the car is practically brand new, less than 2000 miles on it... so i doubt that they burned out.
all i can think of was that i vacuumed and washed my car today... idk! EEERRR!
any ideas?
Old May 2, 2010 | 07:56 PM
Btrthnezr3's Avatar
Ok...try this...
Take a phillips head screw driver and take the screw out of the fog housing, then pull the fog housing away from the bumper...unplug the harness.
Repeat to the other side.
Then make sure they are both dry, and that no clips inside are bent or broken.
Also, check that the bulbs don't have any rattling pieces inside...that they look as if they still have a full ..umm...coil.
Then reclip the harness, reinstall the foglight housing
Repeat for the other side.
Get into the car, turn off your fog switch
Turn on the ignition (won't hurt)
And turn your lights on...then turn on your fog switch
Get out and check...
Eh?
Old May 2, 2010 | 08:02 PM
Raouf's Avatar
i took both off already to see if they were unplugged for some odd reason. but i wasnt smart enough see if they were burnt out... ill go check again.
also i realized what i thought was a big bird crap stain was a big scratch but not too deep.
Old May 2, 2010 | 08:18 PM
hello_you1's Avatar
Did you check the fuse ?
Old May 2, 2010 | 08:31 PM
Raouf's Avatar
yes right after i checked that it wasnt the bulbs, i thought to check the fuses but i seem to not have the fuse puller...so i cant take it out to check
Old May 2, 2010 | 09:03 PM
Btrthnezr3's Avatar
Hrm...local auto store would have an assorted set of fuses with a fuse puller for cheap.
Old May 2, 2010 | 09:10 PM
Raouf's Avatar
well i just found where the puller was, the fuse is fine.
i have to go to the dealership tuesday for them to check out my rear bumper so ill tell them then. its under warranty luckily
thanks for the help tho!!
Digitized
Toronto Community
Nov 29, 2018 02:57 PM
yellow wolf
Dec 4, 2014 09:30 PM
gar1013
116
May 11, 2008 07:44 PM
Hondasforlife
Feb 29, 2008 11:48 PM
Drigo72
Oct 9, 2007 12:33 PM
