DIY request: shift select rod bolt
Old Aug 11, 2009 | 12:25 PM
GD3_Wagoon's Avatar
Exclamation DIY request: shift select rod bolt
Originally Posted by turbosohcabortion
it is really easy to fix this problem before it starts when i install the new gearsets i am going to put red loctite on that bolt and torque the hell out of it some people on here should pull out their shift tower and check their bolt it real easy to do you unhook the 2 dhift cables , there are 4 10mm bolts on the top of the tower then it pulls right out takes less than 20 min to do just make sure you seal the tower back down with hondabond or a good rtv gasket im interested to see if anyone else has a loose bolt i am tryig to get a tsb started with honda tech line if this is a common issue then it is going to be a verry $$$$$$$$$$ issue
does anybody want to take on this DIY? i'm ready to try this but i don't exactly know what i'm looking for.. i change my fluids and have installed all the basic bolt on suspension/exhaust/engine parts but have never tackled anything like this.
doing this could probably help quite a few Fit owners (myself included)
(bumped post from turbosohcabortion's thread: https://www.fitfreak.net/forums/1st-...ion-toast.html)
Old Aug 11, 2009 | 01:23 PM
gimme's Avatar
Master FitFreaker
I may be able to do it in a week or so. this weekend is a bust, son's b-day
Old Aug 11, 2009 | 01:39 PM
GD3_Wagoon's Avatar
HAPPY BIRTHDAY to the little guy
..and thanks, dan!
Old Aug 11, 2009 | 04:10 PM
gd3vbp's Avatar
I would think its as easy as what you've quoted states. All Honda transmissions I've worked on use cotter pins to hold the cables to the shift tower on the tranny. Pop those off, then pull up the 4 10mm bolts and it'll lift off. Then you just need to know which bolt it is thats come loose.
Old Aug 11, 2009 | 05:26 PM
turbosohcabortion's Avatar
i am going to assemble the transmission tomorrow the 5th gearset didnt come in i will do a writeup
Old Aug 12, 2009 | 09:47 PM
gimme's Avatar
Master FitFreaker
did you get it done, turbo?
Old Aug 12, 2009 | 10:05 PM
im sorry didnt get to it at work today because the 2nd gearset is not in yet i cant assemble the trans until i get that in then i will def do a complete writeup sorry for the delay but honda is taking forever to release the part
Old Aug 13, 2009 | 12:39 PM
gimme's Avatar
Master FitFreaker
no worries!
Old Aug 13, 2009 | 04:49 PM
guess what guys gearset is on backorder with no releasedate known they still wont get me a complete transmission and they wont get me a rental i have a call into dan dmartini the honda parts and service district rep i should be hearing from him tomorrow ill keep you updated
Old Aug 13, 2009 | 08:04 PM
gimme's Avatar
Master FitFreaker
oh you're freaking kidding? even their own employee is getting the run around? ffs!
Old Aug 14, 2009 | 12:03 AM
yup honda doesn't have a release date on the gearset it could be tomorrow could be 6 months im hoping soonew than later im driving my friends secound car its a 02 is300 and it horrible on gas i have spent 120 on gas since friday that less than a week my gas cost has more than doubled
Old Aug 22, 2009 | 05:17 PM
Necos07's Avatar
Hey Turbo any word yet???
Old Sep 1, 2009 | 06:26 PM
GD3_Wagoon's Avatar
curiosity BUMP
fm2n
Mar 31, 2018 05:00 AM
airmike
Mar 19, 2012 05:54 PM
Padraic
Nov 4, 2010 06:39 PM
vinnymac
Oct 31, 2010 10:22 PM
kamakurakid
Feb 19, 2009 12:00 PM
