idea and brain storm -- Plexiglass roof
Old Aug 24, 2009 | 07:32 AM
Jodele's Avatar
Use polycarbonate (Lexan AKA bulletproof glass) that is what light aircraft windshields are made of. The way they form the windscreens, is they make a mold and cover it with felt. Then they heat the Lexan sheet to 250 or 350 degrees F…I don’t remember which. Then the hot sheet is draped over the felt covered mold and let cool. The sheet is moved, ever so slightly (jiggled), so the felt texture is not transferred to the sheet. Since your roof is not cut yet, cover it with felt for your mold. There are lots of cars manufactured with the wind shields bonded to the body for rigidity. My suggestion is to leave about 2” on the sides to bond the Lexan to the roof structure. That way, structural integrity will be maintained…that is you won’t need to add structure to the inside of the car.
Take lots of pictures and post them here…
Old Aug 24, 2009 | 12:25 PM
stevet47's Avatar
I think this is the best advise. Definitely use Lexan (waay more expensive than plexiglass, but you don't want to cheap out on this!). I like that molding idea, that is what I was thinking as well, I just didn't know about the felt. I would mold the lexan oversized, then cut the roof, prep/paint/clear/blend the edge, test fit the lexan from the inside, trim where necessary, bond to the roof, reinstall modified headliner, done.
To bond it, I would say put a wide/thick application of clear silicon around the opening, then something like construction adhesive on the rest of the Lexan that will be bonded to the roof. You'll have to figure out a way to get even pressure on it while it dries, but that shouldn't be to hard. While it is drying I would then go clean up and silicon that squeezes out, and I'd try to find a rubber trim (maybe sunroof trim or something) that you can slip in there.
Old Aug 24, 2009 | 12:34 PM
gimme's Avatar
Master FitFreaker
Originally Posted by FELIXY69
CRX comes stock like that ?
in Japan they did.
Old Aug 25, 2009 | 07:30 AM
FELIXY69's Avatar
another thought is that, didnt the JDM GD3 came with glass roof in japan ?
i may get one cut out and ship it over so i can mold it in
Old Aug 25, 2009 | 09:55 AM
stevet47's Avatar
I thought only the GE had the glass roof.
Old Aug 25, 2009 | 03:25 PM
MetalFit630's Avatar
That would rock. I totally say do it! I have always wanted a sunroof in my car. And I really like the moon roof style where the window goes down the middle of the car from front to back. THe Lexan sounds like it'd be better. I'd worry about plexiglass warping and discoloring in excessive sunlight. But I live in Southern California where summer is our only season, so it probably wouldn't work for me!
Old Aug 30, 2009 | 02:33 PM
uRabbit's Avatar
I am very interested in this. I would love to see where you can go with this, as I am wanting to do the same thing. I miss the panoramic moonroof on my Cooper S. This would make our seats' refresh mode even more refreshing.
Old Aug 30, 2009 | 08:01 PM
DrKelso's Avatar
This is almost exactly the first thing that came to mind for this.
LEXAN all the way
Old Sep 9, 2009 | 08:00 AM
Gffy2334's Avatar
the JDM ones did.
Old Sep 9, 2009 | 08:03 AM
Gffy2334's Avatar
i haven't seen a glass roof on a fit since i've been over here. but i only see like 5 a day on base (practically the same 5)
PatrickT
Aug 13, 2016 10:03 PM
phrancis
Apr 16, 2012 11:02 PM
fskelly
Aug 12, 2010 11:59 AM
mikejet
19
Mar 27, 2010 10:53 PM
vtecfit1
Oct 22, 2008 02:52 AM
