My Odometer digital display wont come on
Old Aug 24, 2009 | 11:26 PM
trashercan's Avatar
This morning I didnt get anything on my odometer and trip display. Not sure what else isnt displaying. Anyone have a clue which fuse may be blown ?
Old Aug 24, 2009 | 11:40 PM
Burbio's Avatar
Lucky you. You have a brand new, 0 miles Fit! Sell Sell Sell!!!
Old Aug 25, 2009 | 01:59 PM
trashercan's Avatar
No it wont reset !!!
Just want to know how to get the display to come back...
Old Aug 25, 2009 | 03:07 PM
MetalFit630's Avatar
Chances are it's not a fuse, but the display itself. Check to see if anything else is off. Check all the fuses in the fuse panel. And if you've had any work done in that area, remove panels and double check that all harnesses are plugged in. If everything looks right, you'll probably have to get it check out by a dealership or your local trusted mechanic.
Old Aug 25, 2009 | 04:48 PM
Fit4Pits's Avatar
is it possible you turned the dial way down? to the right of the speedometer is a knob, make sure it isn't turned all the way to the left. probably not it, but worth a shot.
Old Aug 25, 2009 | 07:53 PM
grtpumpkin's Avatar
What he said! That knob turns pretty easy if you aren't careful, take a look at the brightness of your dashboard at night. If you can't see it theres your trouble.
Old Aug 26, 2009 | 12:25 AM
mike2100's Avatar
wow didn't know that knob controlled brightness! you probably accidentally turned it down while wiping down the dash
Old Sep 4, 2009 | 10:48 PM
trashercan's Avatar
No garage said a fuse had blown
Wasnt the dimmer :-) Anyone know which fuse controls this in case it goes again ?
Old Sep 8, 2009 | 05:42 PM
DatFIT's Avatar
should check your manual... it should tell you which is which..
trashercan
Aug 28, 2015 02:13 AM
colin_f
Nov 23, 2013 04:17 AM
Marsbars
Sep 25, 2009 06:47 PM
config
Jun 21, 2008 01:05 PM
kenchan
Dec 23, 2007 09:53 AM
