pioneer speaker
Old Sep 10, 2009 | 10:07 PM
taFITta_sport's Avatar
pioneer speaker
Does anyone know if the premier tsc720prs will fit inside the gd3? I want to put in some new speakers but will the 6 3/4 fit for our 6 1/2's?
Old Sep 11, 2009 | 06:44 AM
Gffy2334's Avatar
check crutchfield.com to see if it will fit. It may even tell you that it fits in the rear but not the front. At the very least Crutchfield will tell you mounting depth.
In any case though I suggest making speaker rings 1/2" to 3/4" thick and drilling them in around the stock speaker hole with self tapping screws then mounting your speakers to the rings.
Good luck.
Old Sep 11, 2009 | 03:25 PM
it's hard to tell because each manufacturer has their own sizing...well, they're generally universal but the way the basket is made, etc. but with the right spacer (or just cutting out your stock speaker and using it as a spacer) might work.
Old Sep 12, 2009 | 12:17 PM
MetalFit630's Avatar
Yes, 6 3/4 inches will fit. The Infinitys I put in are 6 3/4, and my only problem was depth. So check to see what the depth is on the Pioneers. Anything much more than 2 inches means you'll need some spacers. I had to use 3/4 inch spacers to get mine to fit.
Old Sep 15, 2009 | 07:58 PM
thanks guys its just a matter of time before i order them. i was thinking about getting the infinity kappa perfects but i was deciding to go with the premiers since i have a premier head unit.
tleger88
Apr 11, 2014 02:11 AM
feddup
Apr 10, 2012 05:05 PM
dewthedew
May 5, 2011 09:21 PM
vtecboost
Jun 22, 2010 02:33 PM
im the fit
Sep 2, 2009 03:12 PM
